查看: 3013|回復(fù): 2
[已處理] X3.5的默認門戶模板有個小BUG
55
10 個
發(fā)表于 2022-12-6 15:28:51 |浙江| 只看樓主 |倒序瀏覽 |閱讀模式
未啟用生效的門戶分類會在任意門戶欄目中右側(cè)相關(guān)分類里顯示,無法隱藏,這個需要怎么改才能去掉不顯示呢
https://gitee.com/Discuz/DiscuzX/pulls/1826
打開
source/function/function_portal.php
找到
  1. function category_remake($catid) {
  2.         global $_G;
  3.         $cat = $_G['cache']['portalcategory'][$catid];
  4.         if(empty($cat)) return array();
  5.         foreach ($_G['cache']['portalcategory'] as $value) {
  6.                 if($value['catid'] == $cat['upid']) {
  7.                         $cat['ups'][$value['catid']] = $value;
  8.                         $upid = $value['catid'];
  9.                         while(!empty($upid)) {
  10.                                 if(!empty($_G['cache']['portalcategory'][$upid]['upid'])) {
  11.                                         $upid = $_G['cache']['portalcategory'][$upid]['upid'];
  12.                                         $cat['ups'][$upid] = $_G['cache']['portalcategory'][$upid];
  13.                                 } else {
  14.                                         $upid = 0;
  15.                                 }
  16.                         }
  17.                 } elseif($value['upid'] == $cat['catid']) {
  18.                         $cat['subs'][$value['catid']] = $value;
  19.                 } elseif($value['upid'] == $cat['upid']) {
  20.                         $cat['others'][$value['catid']] = $value;
  21.                 }
  22.         }
  23.         if(!empty($cat['ups'])) $cat['ups'] = array_reverse($cat['ups'], TRUE);
  24.         return $cat;
  25. }
替換為
  2.         global $_G;
  5.         require_once libfile('function/portalcp');
  6.         $categoryperm = getallowcategory($_G['uid']);
  7.         foreach ($_G['cache']['portalcategory'] as $value) {
  8.                 if($value['catid'] == $cat['upid']) {
  9.                         $cat['ups'][$value['catid']] = $value;
  10.                         $upid = $value['catid'];
  11.                         while(!empty($upid)) {
  12.                                 if(!empty($_G['cache']['portalcategory'][$upid]['upid'])) {
  13.                                         $upid = $_G['cache']['portalcategory'][$upid]['upid'];
  14.                                         $cat['ups'][$upid] = $_G['cache']['portalcategory'][$upid];
  15.                                 } else {
  16.                                         $upid = 0;
  17.                                 }
  18.                         }
  19.                 } elseif($value['upid'] == $cat['catid']) {
  20.                         $cat['subs'][$value['catid']] = $value;
  21.                 } elseif($value['upid'] == $cat['upid']) {
  22.                         if (!$value['closed'] || $_G['group']['allowdiy'] || $categoryperm[$value['catid']]['allowmanage']) {
  23.                                 $cat['others'][$value['catid']] = $value;
  24.                         }
  25.                 }
  26.         }
  27.         if(!empty($cat['ups'])) $cat['ups'] = array_reverse($cat['ups'], TRUE);
  28.         return $cat;
  29. }
修改后,沒權(quán)限的用戶,不會顯示未啟用的分類
67 點
902 個
發(fā)表于 2022-12-6 15:51:36 |浙江| 只看Ta
打開
找到
  2.         global $_G;
  13.                                 } else {
  14.                                         $upid = 0;
  15.                                 }
  16.                         }
  21.                 }
  22.         }
  24.         return $cat;
  25. }
替換為
  2.         global $_G;
  15.                                 } else {
  16.                                         $upid = 0;
  17.                                 }
  18.                         }
  24.                         }
  25.                 }
  26.         }
  28.         return $cat;
  29. }
謝謝了,我去改下
發(fā)表于 2022-12-6 16:06
GMT+8, 2026-4-18 00:09 , Processed in 0.059728 second(s), 15 queries , Redis On.
