查看: 5030|回復: 2
[已解決] discuz安裝出問題
發(fā)表于 2023-1-10 10:51:36 |上海| 只看樓主 |倒序瀏覽 |閱讀模式
discuz 安裝界面會直接下載個文件,但進入不了安裝界面如圖
打開文件是是:
<?php
*      [Discuz!] (C)2001-2099 Comsenz Inc.
*      This is NOT a freeware, use is subject to license terms
*      $Id: index.php 34524 2014-05-15 04:42:23Z nemohou $
if(version_compare(PHP_VERSION, '9.0.0', '>=')) {
        exit('This version of Discuz! is not compatible with >= PHP 9.0, Please install or update to higher version.');
if(!empty($_SERVER['QUERY_STRING']) && is_numeric($_SERVER['QUERY_STRING'])) {
        $_ENV['curapp'] = 'home';
        $_GET = array('mod'=>'space', 'uid'=>$_SERVER['QUERY_STRING']);
} else {
        $url = '';
        $domain = $_ENV = array();
        $jump = false;
        @include_once './data/sysdata/cache_domain.php';
        $_ENV['domain'] = $domain;
        if(empty($_ENV['domain'])) {
                $_ENV['curapp'] = 'forum';
        } else {
                $_ENV['defaultapp'] = array('portal.php' => 'portal', 'forum.php' => 'forum', 'group.php' => 'group', 'home.php' => 'home');
                $_ENV['hostarr'] = explode('.', $_SERVER['HTTP_HOST']);
                $_ENV['domainroot'] = substr($_SERVER['HTTP_HOST'], strpos($_SERVER['HTTP_HOST'], '.')+1);
                if(!empty($_ENV['domain']['app']) && is_array($_ENV['domain']['app']) && in_array($_SERVER['HTTP_HOST'], $_ENV['domain']['app'])) {
                        $_ENV['curapp'] = array_search($_SERVER['HTTP_HOST'], $_ENV['domain']['app']);
                        if($_ENV['curapp'] == 'mobile') {
                                if(!isset($_GET['mobile'])) {
                                        @$_GET['mobile'] = '2';
                        if($_ENV['curapp'] == 'default' || !isset($_ENV['defaultapp'][$_ENV['curapp'].'.php'])) {
                                $_ENV['curapp'] = '';
                } elseif(!empty($_ENV['domain']['root']) && is_array($_ENV['domain']['root']) && in_array($_ENV['domainroot'], $_ENV['domain']['root'])) {
                        $_G['setting']['holddomain'] = $_ENV['domain']['holddomain'] ? $_ENV['domain']['holddomain'] : array('www');
                        $list = $_ENV['domain']['list'];
                        if(isset($list[$_SERVER['HTTP_HOST']])) {
                                $domain = $list[$_SERVER['HTTP_HOST']];
                                switch($domain['idtype']) {
                                        case 'subarea':
                                                $_GET['gid'] = intval($domain['id']);
                                                break;
                                        case 'forum':
                                                $_GET['mod'] = 'forumdisplay';
                                                $_GET['fid'] = intval($domain['id']);
                                                break;
                                        case 'topic':
                                                $_ENV['curapp'] = 'portal';
                                                $_GET['mod'] = 'topic';
                                                $_GET['topicid'] = intval($domain['id']);
                                                break;
                                        case 'channel':
                                                $_GET['mod'] = 'list';
                                                $_GET['catid'] = intval($domain['id']);
                                                break;
                                        case 'plugin':
                                                $_ENV['curapp'] = 'plugin';
                                                $_GET['id'] = $domain['id'];
                                                $_GET['fromapp'] = 'index';
                                                break;
                        } elseif(count($_ENV['hostarr']) > 2 && $_ENV['hostarr'][0] != 'www' && !checkholddomain($_ENV['hostarr'][0])) {
                                $_ENV['prefixdomain'] = addslashes($_ENV['hostarr'][0]);
                                $_ENV['domainroot'] = addslashes($_ENV['domainroot']);
                                require_once './source/class/class_core.php';
                                C::app()->init_setting = true;
                                C::app()->init_user = false;
                                C::app()->init_session = false;
                                C::app()->init_cron = false;
                                C::app()->init_misc = false;
                                C::app()->init();
                                $jump = true;
                                $domain = C::t('common_domain')->fetch_by_domain_domainroot($_ENV['prefixdomain'], $_ENV['domainroot']);
                                $apphost = $_ENV['domain']['app'][$domain['idtype']] ? $_ENV['domain']['app'][$domain['idtype']] : $_ENV['domain']['app']['default'];
                                $apphost = $apphost ? $_G['scheme'].'://'.$apphost.'/' : '';
                                        case 'home':
                                                if($_G['setting']['rewritestatus'] && is_array($_G['setting']['rewritestatus']) && in_array('home_space', $_G['setting']['rewritestatus'])) {
                                                        $url = rewriteoutput('home_space', 1, $apphost, $domain['id']);
                                                } else {
                                                        $url = $apphost.'home.php?mod=space&uid='.$domain['id'];
                                                break;
                                        case 'group':
                                                if($_G['setting']['rewritestatus'] && is_array($_G['setting']['rewritestatus']) && in_array('group_group', $_G['setting']['rewritestatus'])) {
                                                        $url = rewriteoutput('group_group', 1, $apphost, $domain['id']);
                                                } else {
                                                        $url = $apphost.'forum.php?mod=group&fid='.$domain['id'].'&page=1';
                                                break;
                } else {
                        $jump = true;
                if(empty($url) && empty($_ENV['curapp'])) {
                        if(!empty($_ENV['domain']['defaultindex']) && !$jump) {
                                if($_ENV['defaultapp'][$_ENV['domain']['defaultindex']]) {
                                        $_ENV['curapp'] = $_ENV['defaultapp'][$_ENV['domain']['defaultindex']];
                                } else {
                                        $url = $_ENV['domain']['defaultindex'];
                        } else {
                                if($jump) {
                                        $url = empty($_ENV['domain']['app']['default']) ? (!empty($_ENV['domain']['defaultindex']) ? $_ENV['domain']['defaultindex'] : 'forum.php') : (is_https() ? 'https' : 'http').'://'.$_ENV['domain']['app']['default'];
                                } else {
if(!empty($url)) {
        $delimiter = strrpos($url, '?') ? '&' : '?';
        if(isset($_GET['fromuid']) && $_GET['fromuid']) {
                $url .= sprintf('%sfromuid=%d', $delimiter, $_GET['fromuid']);
        } elseif(isset($_GET['fromuser']) && $_GET['fromuser']) {
                $url .= sprintf('%sfromuser=%s', $delimiter, rawurlencode($_GET['fromuser']));
        $parse = parse_url($url);
        if(!isset($parse['host']) && file_exists($parse['path'])) {
                if(!empty($parse['query'])) {
                        parse_str($parse['query'], $_GET);
                require './'.$parse['path'];
        } else {
                header("location: $url");
} else {
        require './'.$_ENV['curapp'].'.php';
function checkholddomain($domain) {
        global $_G;
        $domain = strtolower($domain);
        if(preg_match("/^[^a-z]/i", $domain)) return true;
        $holdmainarr = empty($_G['setting']['holddomain']) ? array('www') : explode('|', $_G['setting']['holddomain']);
        $ishold = false;
        foreach ($holdmainarr as $value) {
                if(strpos($value, '*') === false) {
                        if(strtolower($value) == $domain) {
                                $ishold = true;
                                break;
                } else {
                        $value = str_replace('*', '.*?', $value);
                        if(@preg_match("/$value/i", $domain)) {
                                $ishold = true;
                                break;
        return $ishold;
function is_https() {
        if(isset($_SERVER['HTTPS']) && strtolower($_SERVER['HTTPS']) != 'off') {
                return true;
        if(isset($_SERVER['HTTP_X_FORWARDED_PROTO']) && strtolower($_SERVER['HTTP_X_FORWARDED_PROTO']) == 'https') {
                return true;
        if(isset($_SERVER['HTTP_X_CLIENT_SCHEME']) && strtolower($_SERVER['HTTP_X_CLIENT_SCHEME']) == 'https') {
                return true;
        if(isset($_SERVER['HTTP_FROM_HTTPS']) && strtolower($_SERVER['HTTP_FROM_HTTPS']) != 'off') {
                return true;
        if(isset($_SERVER['SERVER_PORT']) && $_SERVER['SERVER_PORT'] == 443) {
                return true;
        return false;
看描述大概率是服務器mime設置有問題
發(fā)表于 2023-1-10 11:06:50 |浙江來自手機 | 只看Ta
看描述大概率是服務器mime設置有問題
2076 點
1394 個
發(fā)表于 2023-1-10 13:16:46 |浙江| 只看Ta
一般是服務器不支持php
GMT+8, 2026-4-18 04:16 , Processed in 0.043993 second(s), 14 queries , Redis On.
