- 積分
- 107
- 金幣
- 4 個(gè)
- 社區(qū)幣
- 0 元
- 貢獻(xiàn)
- 0 點(diǎn)
- 金幣
- 4 個(gè)
樓主 |
發(fā)表于 2023-5-5 16:53:54
|福建|
只看Ta
- run_sql_error
- Can not connect to MySQL server
- Error:sorry, now don't support compress for rwsplit.
- Errno:1045
- run_sql_error
- MySQL version must be 5.5.3 or greater
- Errno:1045
- run_sql_error
- SQL:DROP TABLE IF EXISTS pre_ucenter_applications
- Errno:1045
- run_sql_error
- SQL:CREATE TABLE pre_ucenter_applications ( appid smallint(6) unsigned NOT NULL auto_increment, `type` varchar(16) NOT NULL default '', `name` varchar(20) NOT NULL default '', url varchar(255) NOT NULL default '', authkey varchar(255) NOT NULL default '', ip varchar(45) NOT NULL default '', viewprourl varchar(255) NOT NULL, apifilename varchar( 30 ) NOT NULL DEFAULT 'uc.php', charset varchar(8) NOT NULL default '', dbcharset varchar(8) NOT NULL default '', synlogin tinyint(1) NOT NULL default '0', recvnote tinyint(1) DEFAULT '0', extra text NOT NULL, tagtemplates text NOT NULL, allowips text NOT NULL, PRIMARY KEY (appid)) ENGINE=INNODB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
- Errno:1045
- run_sql_error
- SQL:INSERT INTO pre_ucenter_applications SET name='Discuz! Board', url='https://bbs.yanbaojie.com', ip='', authkey='I7UfPaabDee1Dch6h4Ob6b2b8627t3N8U8g8n98f02V4V6Y6P5lar8WdK9R191b1', synlogin='1', charset='utf-8', dbcharset='utf8mb4', type='DISCUZX', recvnote='1', tagtemplates=''
- Errno:1045
- run_sql_error
- SQL:ALTER TABLE pre_ucenter_notelist ADD COLUMN app tinyint NOT NULL
- Errno:1045
- run_sql_error
- SQL:INSERT INTO pre_ucenter_members SET username='admin', password='$2y$10$98GOqYx4sODx.7fCkjfnxePITaLW0IiQS1kQGPR5KMniCvPRMn9Ti', email='admin@admin.com', regip='hidden', regdate='1683276749', salt=''
- Errno:1045
- run_sql_error
- SQL:INSERT INTO pre_ucenter_memberfields SET uid=''
- Errno:1045
- run_sql_error
- SQL:INSERT INTO pre_ucenter_admins SET uid='', username='admin', allowadminsetting='1', allowadminapp='1', allowadminuser='1', allowadminbadword='1', allowadmincredits='1', allowadmintag='1', allowadminpm='1', allowadmindomain='1', allowadmindb='1', allowadminnote='1', allowadmincache='1', allowadminlog='1'
- Errno:1045
- run_sql_error
- SQL:DROP TABLE IF EXISTS pre_common_admincp_cmenu
- Errno:1045
復(fù)制代碼 |
