if(!defined('IN_DISCUZ')) {
exit('Access Denied');
$defaultop = '';
$profilegroup = C::t('common_setting')->fetch('profilegroup', true);
foreach($profilegroup as $key => $value) {
if($value['available']) {
$defaultop = $key;
break;
$operation = in_array($_GET['op'], array('base', 'contact', 'edu', 'work', 'info', 'password', 'verify')) ? trim($_GET['op']) : $defaultop;
$space = getuserbyuid($_G['uid']);
space_merge($space, 'field_home');
space_merge($space, 'profile');
list($seccodecheck, $secqaacheck) = seccheck('password');
@include_once DISCUZ_ROOT.'./data/cache/cache_domain.php';
$spacedomain = isset($rootdomain['home']) && $rootdomain['home'] ? $rootdomain['home'] : array();
$_GET['id'] = $_GET['id'] ? preg_replace("/[^A-Za-z0-9_:]/", '', $_GET['id']) : '';
if($operation != 'password') {
include_once libfile('function/profile');
loadcache('profilesetting');
if(empty($_G['cache']['profilesetting'])) {
require_once libfile('function/cache');
updatecache('profilesetting');
$allowcstatus = !empty($_G['group']['allowcstatus']) ? true : false;
$verify = C::t('common_member_verify')->fetch($_G['uid']);
if(!empty($verify) && is_array($verify)) {
foreach($verify as $key => $flag) {
if(in_array($key, array('verify1', 'verify2', 'verify3', 'verify4', 'verify5', 'verify6', 'verify7')) && $flag == 1) {
$verifyid = intval(substr($key, -1, 1));
if($_G['setting']['verify'][$verifyid]['available']) {
foreach($_G['setting']['verify'][$verifyid]['field'] as $field) {
$_G['cache']['profilesetting'][$field]['unchangeable'] = 1;
$validate = array();
if($_G['setting']['regverify'] == 2 && $_G['groupid'] == 8) {
$validate = C::t('common_member_validate')->fetch($_G['uid']);
if(empty($validate) || $validate['status'] != 1) {
if($_G['setting']['connect']['allow']) {
$connect = C::t('#qqconnect#common_member_connect')->fetch($_G['uid']);
$conisregister = $operation == 'password' && $connect['conisregister'];
if(in_array('wechat', $_G['setting']['plugins']['available'])) {
if($_G['wechat']['setting']['wechat_qrtype']) {
$wechatuser = C::t('#wechat#common_member_wechatmp')->fetch($_G['uid']);
if($wechatuser && !$wechatuser['status']) {
$wechatuser['isregister'] = 1;
} else {
$wechatuser = C::t('#wechat#common_member_wechat')->fetch($_G['uid']);
$conisregister = $operation == 'password' && $wechatuser['isregister'];
if(submitcheck('profilesubmit')) {
require_once libfile('function/discuzcode');
$forum = $setarr = $verifyarr = $errorarr = array();
$forumfield = array('customstatus', 'sightml');
$censor = discuz_censor::instance();
if($_GET['vid']) {
$vid = intval($_GET['vid']);
if (getuserprofile('verify' . $vid) == 1) {
showmessage('spacecp_profile_message2');
$verifyconfig = $_G['setting']['verify'][$vid];
if($verifyconfig['available'] && (empty($verifyconfig['groupid']) || in_array($_G['groupid'], $verifyconfig['groupid']))) {
$verifyinfo = C::t('common_member_verify_info')->fetch_by_uid_verifytype($_G['uid'], $vid);
if(!empty($verifyinfo)) {
$verifyinfo['field'] = dunserialize($verifyinfo['field']);
foreach($verifyconfig['field'] as $key => $field) {
if(!isset($verifyinfo['field'][$key])) {
$verifyinfo['field'][$key] = $key;
} else {
$_GET['vid'] = $vid = 0;
$verifyconfig = array();
if(isset($_POST['birthprovince'])) {
$initcity = array('birthprovince', 'birthcity', 'birthdist', 'birthcommunity');
foreach($initcity as $key) {
$_GET[''.$key] = $_POST[$key] = !empty($_POST[$key]) ? $_POST[$key] : '';
if(isset($_POST['resideprovince'])) {
$initcity = array('resideprovince', 'residecity', 'residedist', 'residecommunity');
foreach($_POST as $key => $value) {
$field = $_G['cache']['profilesetting'][$key];
if(in_array($field['formtype'], array('text', 'textarea')) || in_array($key, $forumfield)) {
$censor->check($value);
if($censor->modbanned() || $censor->modmoderated()) {
profile_showerror($key, lang('spacecp', 'profile_censor'));
if(in_array($key, $forumfield)) {
if($key == 'sightml') {
loadcache(array('smilies', 'smileytypes'));
$value = cutstr($value, $_G['group']['maxsigsize'], '');
foreach($_G['cache']['smilies']['replacearray'] AS $skey => $smiley) {
$_G['cache']['smilies']['replacearray'][$skey] = '[img]'.$_G['siteurl'].'static/image/smiley/'.$_G['cache']['smileytypes'][$_G['cache']['smilies']['typearray'][$skey]]['directory'].'/'.$smiley.'[/img]';
$value = preg_replace($_G['cache']['smilies']['searcharray'], $_G['cache']['smilies']['replacearray'], trim($value));
$forum[$key] = discuzcode($value, 1, 0, 0, 0, $_G['group']['allowsigbbcode'], $_G['group']['allowsigimgcode'], 0, 0, 1);
} elseif($key=='customstatus' && $allowcstatus) {
$forum[$key] = dhtmlspecialchars(trim($value));
continue;
} elseif($field && !$field['available']) {
continue;
} elseif($key == 'timeoffset') {
if($value >= -12 && $value <= 12 || $value == 9999) {
C::t('common_member')->update($_G['uid'], array('timeoffset' => intval($value)));
} elseif($key == 'site') {
if(!in_array(strtolower(substr($value, 0, 6)), array('http:/', 'https:', 'ftp://', 'rtsp:/', 'mms://')) && !preg_match('/^static\//', $value) && !preg_match('/^data\//', $value)) {
$value = 'http://'.$value;
if($field['formtype'] == 'file') {
if((!empty($_FILES[$key]) && $_FILES[$key]['error'] == 0) || (!empty($space[$key]) && empty($_GET['deletefile'][$key]))) {
$value = '1';
} else {
$value = '';
if(empty($field)) {
continue;
} elseif(profile_check($key, $value, $space)) {
$setarr[$key] = dhtmlspecialchars(trim($value));
} else {
if($key=='birthprovince') {
$key = 'birthcity';
} elseif($key=='resideprovince' || $key=='residecommunity'||$key=='residedist') {
$key = 'residecity';
} elseif($key=='birthyear' || $key=='birthmonth') {
$key = 'birthday';
profile_showerror($key);
unset($setarr[$key]);
if (isset($setarr[$key]) && $_G['cache']['profilesetting'][$key]['unchangeable'] && $space[$key]) {
if($vid && $verifyconfig['available'] && isset($verifyconfig['field'][$key])) {
if(isset($verifyinfo['field'][$key]) && $setarr[$key] !== $space[$key]) {
$verifyarr[$key] = $setarr[$key];
if(isset($setarr[$key]) && $_G['cache']['profilesetting'][$key]['needverify']) {
if($setarr[$key] !== $space[$key]) {
if($_GET['deletefile'] && is_array($_GET['deletefile'])) {
foreach($_GET['deletefile'] as $key => $value) {
if(isset($_G['cache']['profilesetting'][$key]) && $_G['cache']['profilesetting'][$key]['formtype'] == 'file') {
$verifyarr[$key] = $setarr[$key] = '';
if($_FILES) {
$upload = new discuz_upload();
foreach($_FILES as $key => $file) {
if(!isset($_G['cache']['profilesetting'][$key])) {
continue;
if((!empty($file) && $file['error'] == 0) || (!empty($space[$key]) && empty($_GET['deletefile'][$key]))) {
$value = '1';
} else {
$value = '';
if(!profile_check($key, $value, $space)) {
} elseif($field['size'] && $field['size']*1024 < $file['size']) {
profile_showerror($key, lang('spacecp', 'filesize_lessthan').$field['size'].'KB');
} elseif($_G['cache']['profilesetting'][$key]['unchangeable'] && !empty($space[$key])){
$upload->init($file, 'profile');
$attach = $upload->attach;
if(!$upload->error()) {
$upload->save();
if(!$upload->get_image_info($attach['target'])) {
@unlink($attach['target']);
continue;
$setarr[$key] = '';
$attach['attachment'] = dhtmlspecialchars(trim($attach['attachment']));
if(isset($verifyinfo['field'][$key])) {
$verifyarr[$key] = $attach['attachment'];
continue;
continue;
$setarr[$key] = $attach['attachment'];
if($vid && !empty($verifyinfo['field']) && is_array($verifyinfo['field'])) {
foreach($verifyinfo['field'] as $key => $fvalue) {
if(!isset($verifyconfig['field'][$key])) {
unset($verifyinfo['field'][$key]);
continue;
if(empty($verifyarr[$key]) && !isset($verifyarr[$key]) && isset($verifyinfo['field'][$key])) {
$verifyarr[$key] = !empty($fvalue) && $key != $fvalue ? $fvalue : $space[$key];
if($forum) {
if(!$_G['group']['maxsigsize']) {
$forum['sightml'] = '';
C::t('common_member_field_forum')->update($_G['uid'], $forum);
if(isset($_POST['birthmonth']) && ($space['birthmonth'] != $_POST['birthmonth'] || $space['birthday'] != $_POST['birthday'])) {
$setarr['constellation'] = get_constellation($_POST['birthmonth'], $_POST['birthday']);
if(isset($_POST['birthyear']) && $space['birthyear'] != $_POST['birthyear']) {
$setarr['zodiac'] = get_zodiac($_POST['birthyear']);
if($setarr) {
C::t('common_member_profile')->update($_G['uid'], $setarr);
if($verifyarr) {
C::t('common_member_verify_info')->delete_by_uid($_G['uid'], $vid);
$setverify = array(
'uid' => $_G['uid'],
'username' => $_G['username'],
'verifytype' => $vid,
'field' => serialize($verifyarr),
'dateline' => $_G['timestamp']
C::t('common_member_verify_info')->insert($setverify);
if(!(C::t('common_member_verify')->count_by_uid($_G['uid']))) {
C::t('common_member_verify')->insert(array('uid' => $_G['uid']));
if($_G['setting']['verify'][$vid]['available']) {
manage_addnotify('verify_'.$vid, 0, array('langkey' => 'manage_verify_field', 'verifyname' => $_G['setting']['verify'][$vid]['title'], 'doid' => $vid));
if(isset($_POST['privacy'])) {
foreach($_POST['privacy'] as $key=>$value) {
if(isset($_G['cache']['profilesetting'][$key])) {
$space['privacy']['profile'][$key] = intval($value);
C::t('common_member_field_home')->update($space['uid'], array('privacy'=>serialize($space['privacy'])));
manyoulog('user', $_G['uid'], 'update');
include_once libfile('function/feed');
feed_add('profile', 'feed_profile_update_'.$operation, array('hash_data'=>'profile'));
countprofileprogress();
$message = $vid ? lang('spacecp', 'profile_verify_verifying', array('verify' => $verifyconfig['title'])) : '';
profile_showsuccess($message);
} elseif(submitcheck('passwordsubmit', 0, $seccodecheck, $secqaacheck)) {
$membersql = $memberfieldsql = $authstradd1 = $authstradd2 = $newpasswdadd = '';
$setarr = array();
$emailnew = dhtmlspecialchars($_GET['emailnew']);
$ignorepassword = 0;
if($connect['conisregister']) {
$_GET['oldpassword'] = '';
$ignorepassword = 1;
if(empty($_GET['newpassword'])) {
showmessage('profile_passwd_empty');
if(in_array('mobile', $_G['setting']['plugins']['available']) && $wechatuser['isregister']) {
if($_GET['questionidnew'] === '') {
$_GET['questionidnew'] = $_GET['answernew'] = '';
} else {
$secquesnew = $_GET['questionidnew'] > 0 ? random(8) : '';
if(!empty($_GET['newpassword']) && $_G['setting']['strongpw']) {
$strongpw_str = array();
if(in_array(1, $_G['setting']['strongpw']) && !preg_match("/\d+/", $_GET['newpassword'])) {
$strongpw_str[] = lang('member/template', 'strongpw_1');
if(in_array(2, $_G['setting']['strongpw']) && !preg_match("/[a-z]+/", $_GET['newpassword'])) {
$strongpw_str[] = lang('member/template', 'strongpw_2');
if(in_array(3, $_G['setting']['strongpw']) && !preg_match("/[A-Z]+/", $_GET['newpassword'])) {
$strongpw_str[] = lang('member/template', 'strongpw_3');
if(in_array(4, $_G['setting']['strongpw']) && !preg_match("/[^a-zA-z0-9]+/", $_GET['newpassword'])) {
$strongpw_str[] = lang('member/template', 'strongpw_4');
if($strongpw_str) {
showmessage(lang('member/template', 'password_weak').implode(',', $strongpw_str));
if(!empty($_GET['newpassword']) && $_GET['newpassword'] != addslashes($_GET['newpassword'])) {
showmessage('profile_passwd_illegal', '', array(), array('return' => true));
if(!empty($_GET['newpassword']) && $_GET['newpassword'] != $_GET['newpassword2']) {
showmessage('profile_passwd_notmatch', '', array(), array('return' => true));
loaducenter();
if($emailnew != $_G['member']['email']) {
include_once libfile('function/member');
checkemail($emailnew);
$ucresult = uc_user_edit(addslashes($_G['username']), $_GET['oldpassword'], $_GET['newpassword'], '', $ignorepassword, $_GET['questionidnew'], $_GET['answernew']);
if($ucresult == -1) {
showmessage('profile_passwd_wrong', '', array(), array('return' => true));
} elseif($ucresult == -4) {
showmessage('profile_email_illegal', '', array(), array('return' => true));
} elseif($ucresult == -5) {
showmessage('profile_email_domain_illegal', '', array(), array('return' => true));
} elseif($ucresult == -6) {
showmessage('profile_email_duplicate', '', array(), array('return' => true));
if(!empty($_GET['newpassword']) || $secquesnew) {
$setarr['password'] = md5(random(10));
C::t('#qqconnect#common_member_connect')->update($_G['uid'], array('conisregister' => 0));
C::t('#wechat#common_member_wechat')->update($_G['uid'], array('isregister' => 0));
$authstr = false;
if(emailcheck_send($space['uid'], $emailnew)) {
$authstr = true;
dsetcookie('newemail', "{$space['uid']}\t$emailnew\t{$_G['timestamp']}", 31536000);
if($setarr) {
if($_G['member']['freeze'] == 1) {
$setarr['freeze'] = 0;
C::t('common_member')->update($_G['uid'], $setarr);
if($_G['member']['freeze'] == 2 || $_G['member']['freeze'] == -1) {
$status = C::t('common_member_validate')->fetch($_G['uid']);
if($status) {
C::t('common_member_validate')->update($_G['uid'], array(
'submitdate' => TIMESTAMP,
'submittimes' => $status['submittimes'] + 1,
'status' => 0,
'message' => dhtmlspecialchars(addslashes($_POST['freezereson'])),
} else {
C::t('common_member_validate')->insert(array(
'moddate' => 0,
'admin' => '',
'submittimes' => 1,
'status' => 0,
'remark' => '',
), false, true);
manage_addnotify('verifyuser');
if($authstr) {
showmessage('profile_email_verify', 'home.php?mod=spacecp&ac=profile&op=password');
} else {
showmessage('profile_succeed', 'home.php?mod=spacecp&ac=profile&op=password');
if($operation == 'password') {
$interval = $_G['setting']['mailinterval'] > 0 ? (int)$_G['setting']['mailinterval'] : 300;
$resend = getcookie('resendemail');
$resend = empty($resend) ? true : (TIMESTAMP - $resend) > $interval;
$newemail = getcookie('newemail');
$space['newemail'] = !$space['emailstatus'] ? $space['email'] : '';
if(!empty($newemail)) {
$mailinfo = explode("\t", $newemail);
if(is_array($mailinfo) && $mailinfo[0] == $_G['uid'] && isemail($mailinfo[1])) {
if($space['emailstatus'] && !$space['freeze'] && strcasecmp($mailinfo[1], $space['email']) === 0) {
dsetcookie('newemail', '', -1);
$space['newemail'] = '';
} else {
$space['newemail'] = $mailinfo[1];
if($_GET['resend'] && $resend && $_GET['formhash'] == FORMHASH) {
$toemail = $space['newemail'] ? $space['newemail'] : $space['email'];
if(emailcheck_send($space['uid'], $toemail)) {
dsetcookie('newemail', "{$space['uid']}\t$toemail\t{$_G['timestamp']}", 31536000);
dsetcookie('resendemail', TIMESTAMP);
showmessage('send_activate_mail_succeed', "home.php?mod=spacecp&ac=profile&op=password");
} else {
showmessage('send_activate_mail_error', 'home.php?mod=spacecp&ac=profile&op=password', array('interval' => $interval));
} elseif ($_GET['resend']) {
if(!empty($space['newemail'])) {
$acitvemessage = lang('spacecp', 'email_acitve_message', array('newemail' => $space['newemail'], 'imgdir' => $_G['style']['imgdir'], 'formhash' => FORMHASH));
$actives = array('password' =>' class="a"');
$navtitle = lang('core', 'title_password_security');
$fzvalidate = C::t('common_member_validate')->fetch($space['uid']);
$space['freezereson'] = $fzvalidate['message'];
$space['freezemodremark'] = $fzvalidate['remark'];
$space['freezemoddate'] = dgmdate($fzvalidate['moddate'], 'Y-m-d H:i:s');
$space['freezemodadmin'] = $fzvalidate['admin'];
$space['freezemodsubmittimes'] = $fzvalidate['submittimes'];
} else {
space_merge($space, 'field_forum');
require_once libfile('function/editor');
$space['sightml'] = html2bbcode($space['sightml']);
$vid = $_GET['vid'] ? intval($_GET['vid']) : 0;
$privacy = $space['privacy']['profile'] ? $space['privacy']['profile'] : array();
$_G['setting']['privacy'] = $_G['setting']['privacy'] ? $_G['setting']['privacy'] : array();
$_G['setting']['privacy'] = is_array($_G['setting']['privacy']) ? $_G['setting']['privacy'] : dunserialize($_G['setting']['privacy']);
$_G['setting']['privacy']['profile'] = !empty($_G['setting']['privacy']['profile']) ? $_G['setting']['privacy']['profile'] : array();
$privacy = array_merge($_G['setting']['privacy']['profile'], $privacy);
$actives = array('profile' =>' class="a"');
$opactives = array($operation =>' class="a"');
$allowitems = array();
if(in_array($operation, array('base', 'contact', 'edu', 'work', 'info'))) {
$allowitems = $profilegroup[$operation]['field'];
} elseif($operation == 'verify') {
if($vid == 0) {
foreach($_G['setting']['verify'] as $key => $setting) {
if($setting['available'] && (empty($setting['groupid']) || in_array($_G['groupid'], $setting['groupid']))) {
$_GET['vid'] = $vid = $key;
break;
if(empty($_G['setting']['verify'][$vid]['groupid']) || in_array($_G['groupid'], $_G['setting']['verify'][$vid]['groupid'])) {
$actives = array('verify' =>' class="a"');
$opactives = array($operation.$vid =>' class="a"');
$allowitems = $_G['setting']['verify'][$vid]['field'];
$showbtn = ($vid && $verify['verify'.$vid] != 1) || empty($vid);
if($vid) {
if($value = C::t('common_member_verify_info')->fetch_by_uid_verifytype($_G['uid'], $vid)) {
$field = dunserialize($value['field']);
foreach($field as $key => $fvalue) {
$space[$key] = $fvalue;
$htmls = $settings = array();
foreach($allowitems as $fieldid) {
if(!in_array($fieldid, array('sightml', 'customstatus', 'timeoffset'))) {
$html = profile_setting($fieldid, $space, $vid ? false : true);
if($html) {
$settings[$fieldid] = $_G['cache']['profilesetting'][$fieldid];
$htmls[$fieldid] = $html;
include template("home/spacecp_profile");
function profile_showerror($key, $extrainfo = '') {
echo '<script>';
echo 'parent.show_error("'.$key.'", "'.$extrainfo.'");';
echo '</script>';
exit();
function profile_showsuccess($message = '') {
echo '<script type="text/javascript">';
echo "parent.show_success('$message');";
echo '</script>';
exit();
