查看: 3226|回復(fù): 15
[已解決] 抱歉,你尚未輸入標(biāo)題或內(nèi)容
11
10 個
發(fā)表于 2024-1-9 09:15:25 |湖北| 只看樓主 |倒序瀏覽 |閱讀模式
dzx3.5會員發(fā)帖,明明寫了標(biāo)題和內(nèi)容,經(jīng)常出現(xiàn)  “抱歉,你尚未輸入標(biāo)題或內(nèi)容”
請問是哪個環(huán)節(jié)出了問題?大家遇到過沒?
會員權(quán)限設(shè)置是正常的
升級3.5后,發(fā)帖時出現(xiàn),(抱歉,您尚未輸入標(biāo)題或內(nèi)容)  怎樣處理呢
解決方法,打開文件編輯:template\one_simple\forum\post.php
第一行的JS代碼全部刪除掉
  1. <script type="text/javascript">
換成下面的代碼即可
  2.         var allowpostattach = parseInt('{$_G['group']['allowpostattach']}');
  3.         var allowpostimg = parseInt('$allowpostimg');
  4.         var pid = parseInt('$pid');
  5.         var tid = parseInt('$_G[tid]');
  6.         var extensions = '{$_G['group']['attachextensions']}';
  7.         var imgexts = '$imgexts';
  8.         var postminchars = parseInt('$_G['setting']['minpostsize']');
  9.         var postmaxchars = parseInt('$_G['setting']['maxpostsize']');
  10.         var postminsubjectchars = parseInt('$_G['setting']['minsubjectsize']');
  11.         var postmaxsubjectchars = parseInt('$_G['setting']['maxsubjectsize']');
  12.         var disablepostctrl = parseInt('{$_G['group']['disablepostctrl']}');
  13.         var seccodecheck = parseInt('<!--{if $seccodecheck}-->1<!--{else}-->0<!--{/if}-->');
  14.         var secqaacheck = parseInt('<!--{if $secqaacheck}-->1<!--{else}-->0<!--{/if}-->');
  15.         var typerequired = parseInt('{$_G[forum][threadtypes][required] or ''}');
  16.         var sortrequired = parseInt('{$_G[forum][threadsorts][required] or ''}');
  17.         var special = parseInt('$special');
  18.         var isfirstpost = <!--{if $isfirstpost}-->1<!--{else}-->0<!--{/if}-->;
  19.         var allowposttrade = parseInt('{$_G['group']['allowposttrade']}');
  20.         var allowpostreward = parseInt('{$_G['group']['allowpostreward']}');
  21.         var allowpostactivity = parseInt('{$_G['group']['allowpostactivity']}');
  22.         var sortid = parseInt('$sortid');
  23.         var special = parseInt('$special');
  24.         var fid = $_G['fid'];
  25.         var postaction = '{$_GET['action']}';
  26.         var ispicstyleforum = <!--{if $_G['forum']['picstyle']}-->1<!--{else}-->0<!--{/if}-->;
  27. </script>
實際上就是新版本在發(fā)帖上做了調(diào)整,舊版本自定義的模版變量缺少了導(dǎo)致的,上面的JS是從3.5最新版官方模版提取的代碼
搬運的,你試試行不行
10 個
置頂 來自 8#
 樓主| 發(fā)表于 2024-1-10 11:42:56 |湖北| 只看Ta
luolongwei 發(fā)表于 2024-1-9 22:22
解決方法,打開文件編輯:template\ ...
找不到你說的文件夾和文件,找半天,謝謝
他說的路徑是 template\你現(xiàn)在用的模板\forum\post.php,如果是用默認模板,路徑就是template\default\forum\post.php
發(fā)表于 2024-1-10 11:58
10 個
 樓主| 發(fā)表于 2024-1-9 09:18:59 |湖北| 只看Ta
看了會員權(quán)限,版塊權(quán)限都是正常設(shè)置,不知道哪出了問題,或者哪里設(shè)置出了問題
發(fā)表于 2024-1-9 09:34:07 |河南| 只看Ta
估計文件有損壞, 或者是某插件導(dǎo)致!
10 個
 樓主| 發(fā)表于 2024-1-9 09:36:47 |湖北| 只看Ta
天外飄仙 發(fā)表于 2024-1-9 09:34
我?guī)缀鯖]有啥插件,除了QQ登錄,莫非是對應(yīng)的發(fā)帖文件或則模塊
發(fā)表于 2024-1-9 10:24:20 |河南| 只看Ta
羅漢果999 發(fā)表于 2024-1-9 09:36
那就校檢一下文件;
不行的話 直接用原版dz文件覆蓋一下! 完了 記得更新緩存
20 點
18 個
發(fā)表于 2024-1-9 10:24:20 |廣東| 只看Ta
這個我之前遇到過,剛升級3.5的時候,后來付費找人處理了,好像是JS沖突。
不知道啥沖突,不明白,謝謝
發(fā)表于 2024-1-10 11:51
發(fā)表于 2024-1-9 22:22:57 |廣東| 只看Ta
第一行的JS代碼全部刪除掉
換成下面的代碼即可
  27. </script>
搬運的,你試試行不行
10 個
 樓主| 發(fā)表于 2024-1-10 11:50:35 |湖北| 只看Ta
天外飄仙 發(fā)表于 2024-1-9 10:24
那就校檢一下文件;
不行的話 直接用原版dz文件覆蓋一下! 完了 記得更新緩存 ...
您是說3.5最新版在覆蓋一次,還用不用整old文件夾.移動后再又搬出來再覆蓋還原,還是只用用DZ3.5的部分文件或者文件夾直接一次覆蓋,比如只有forum.php覆蓋一下啥的,不懂怎么覆蓋
發(fā)表于 2024-1-10 15:34:56 |河南| 只看Ta
羅漢果999 發(fā)表于 2024-1-10 11:50
您是說3.5最新版在覆蓋一次,還用不用整old文件夾.移動后再又搬出來再覆蓋還原,還是只用用DZ3.5的部分文 ...
不用移動,直接覆蓋! 建議先備份
GMT+8, 2026-4-18 02:53 , Processed in 0.060756 second(s), 19 queries , Redis On.
