查看: 671|回復(fù): 1
[求助] 付費(fèi)解決服務(wù)器mysql啟動(dòng)不了問題
49
33 個(gè)
發(fā)表于 2024-7-7 11:51:41 |福建| 只看樓主 |倒序?yàn)g覽 |閱讀模式
  1. 2024-07-07T03:50:08.473163Z 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
  2. 2024-07-07T03:50:08.473283Z 0 [Warning] 'NO_ZERO_DATE', 'NO_ZERO_IN_DATE' and 'ERROR_FOR_DIVISION_BY_ZERO' sql modes should be used with strict mode. They will be merged with strict mode in a future release.
  3. 2024-07-07T03:50:08.473300Z 0 [Warning] 'NO_AUTO_CREATE_USER' sql mode was not set.
  4. 2024-07-07T03:50:08.473327Z 0 [Note] --secure-file-priv is set to NULL. Operations related to importing and exporting data are disabled
  5. 2024-07-07T03:50:08.473362Z 0 [Note] /www/server/mysql/bin/mysqld (mysqld 5.7.41-log) starting as process 7663 ...
  6. 2024-07-07T03:50:08.478436Z 0 [Warning] Can't create test file /www/server/data/iZ23u3vtdliZ.lower-test
  7. 2024-07-07T03:50:08.478474Z 0 [Warning] Can't create test file /www/server/data/iZ23u3vtdliZ.lower-test
  8. mysqld: File './mysql-bin.~rec~' not found (Errcode: 28 - No space left on device)
  9. 2024-07-07T03:50:08.480830Z 0 [ERROR] MYSQL_BIN_LOG::open_purge_index_file failed to open register  file.
  10. 2024-07-07T03:50:08.480838Z 0 [ERROR] MYSQL_BIN_LOG::open_index_file failed to sync the index file.
  11. 2024-07-07T03:50:08.480841Z 0 [ERROR] Aborting
  12. 2024-07-07T03:50:08.480853Z 0 [Note] Binlog end
  13. 2024-07-07T03:50:08.481014Z 0 [Note] /www/server/mysql/bin/mysqld: Shutdown complete
錯(cuò)誤日志是這樣的,啟動(dòng)不了了,付費(fèi)解決。
官方有償服務(wù)QQ 1453650
180 點(diǎn)
240005 個(gè)
發(fā)表于 2024-7-10 00:17:49 |浙江| 只看Ta
可以聯(lián)系
GMT+8, 2026-4-18 10:34 , Processed in 0.049092 second(s), 13 queries , Redis On.
