SQL 配置
innodb_flush_log_at_trx_commit 設置為2 不再提示這個.但是提示
正在系統(tǒng)初始化 ...
HTTP 503 失敗 <!DOCTYPE html>
<html>
<head>
<title>bbs.wdy.vip - Database Error</title>
<meta charset="utf-8" />
<meta name="renderer" content="webkit" />
<meta http-equiv="X-UA-Compatible" content="IE=edge" />
<meta name="ROBOTS" content="NOINDEX,NOFOLLOW,NOARCHIVE" />
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<style type="text/css">
body { background-color: white; color: black; font: 9pt/11pt verdana, arial, sans-serif;}
#container { max-width: 1024px; margin: auto; }
#message { max-width: 1024px; color: black; }
.red {color: red;}
a:link { font: 9pt/11pt verdana, arial, sans-serif; color: red; }
a:visited { font: 9pt/11pt verdana, arial, sans-serif; color: #4e4e4e; }
a.guess { font: 11pt/13pt verdana, arial, sans-serif; color: blue; }
h1 { color: #FF0000; font: 18pt "Verdana"; margin-bottom: 0.5em;}
.bg1{ background-color: #FFFFCC;}
.bg2{ background-color: #EEEEEE;}
.bg3{ background-color: #FFA66C; font-weight: bold;}
.table {background: #AAAAAA; font: 11pt Menlo,Consolas,"Lucida Console";}
.table tbody{word-break: break-all;}
.info {
background: none repeat scroll 0 0 #F3F3F3;
border: 0px solid #aaaaaa;
border-radius: 10px 10px 10px 10px;
color: #000000;
font-size: 11pt;
line-height: 160%;
margin-bottom: 1em;
padding: 1em;
.info svg { width: 40%; min-width: 200px; display: block; margin: auto; margin-bottom: 30px; fill: #999; }
.info svg .xicon { fill: #d31f0d; }
.help {
background: #F3F3F3;
font: 14px verdana, arial, sans-serif;
text-align: center;
line-height: 160%;
padding: 1em;
margin: 1em 0;
.sql {
background: none repeat scroll 0 0 #FFFFCC;
border: 1px solid #aaaaaa;
color: #000000;
font: arial, sans-serif;
font-size: 9pt;
line-height: 160%;
margin-top: 1em;
padding: 4px;
</style>
</head>
<body>
<div id="container">
<h1>Discuz! Database Error</h1><p>Time: 2024-11-03 08:37:12 +0000 IP: 192.168.111.2 BackTraceID: d1e764edf325012c5a078e7a21093f85</p><div class="info">(1146) Table 'sql24001.portal_category' doesn't exist<div class="sql">SELECT * FROM portal_category ORDER BY displayorder,catid</div></div><div class="info"><p><strong>PHP Debug</strong></p><table cellpadding="5" cellspacing="1" width="100%" class="table"><tr class="bg2"><td>No.</td><td>File</td><td>Line</td><td>Code</td></tr><tr class="bg1"><td>1</td><td>misc.php</td><td>96</td><td>require(%s)</td></tr><tr class="bg1"><td>2</td><td>source/module/misc/misc_initsys.php</td><td>29</td><td>updatecache()</td></tr><tr class="bg1"><td>3</td><td>source/function/function_cache.php</td><td>26</td><td>build_cache_portalcategory()</td></tr><tr class="bg1"><td>4</td><td>source/function/cache/cache_portalcategory.php</td><td>17</td><td>table_portal_category->range_category()</td></tr><tr class="bg1"><td>5</td><td>source/class/table/table_portal_category.php</td><td>57</td><td>discuz_database::query()</td></tr><tr class="bg1"><td>6</td><td>source/class/discuz/discuz_database.php</td><td>142</td><td>db_driver_mysqli->query()</td></tr><tr class="bg1"><td>7</td><td>source/class/db/db_driver_mysqli.php</td><td>147</td><td>db_driver_mysqli->halt()</td></tr><tr class="bg1"><td>8</td><td>source/class/db/db_driver_mysqli.php</td><td>222</td><td>break()</td></tr></table></div><div class="help">如果您是用戶,建議您嘗試刷新頁面、關閉所有瀏覽器窗口重新進行操作。如果無法解決,建議您完整截圖本頁面并保存,隨后向站點管理員反饋此問題</div><div class="help">如果您是站點管理員,建議您嘗試在管理中心 <a href="admin.php?action=tools&operation=updatecache&frames=yes" target="_blank">更新緩存</a> ,或憑完整截圖通過 <a href="http://m.sdtechgong.com.cn/" target="_blank">官方論壇</a> 尋求幫助。如果您確定是程序自身Bug,您也可直接 <a href="https://gitee.com/discuz/DiscuzX/issues" target="_blank">提交Issue</a> 給我們</div><div class="help"><a href="http://bbs.wdy.vip">bbs.wdy.vip</a> 已經(jīng)將此出錯信息詳細記錄, 由此給您帶來的訪問不便我們深感歉意</div>
</div>
</body>
</html>
您必須解決以上問題,安裝才可以繼續(xù) |
