查看: 1322|回復: 3
[已解決] 請問手機內(nèi)容頁匿名用戶頭像如何修改為自定義頭像
19
3 點
2 個
發(fā)表于 2024-11-19 22:48:03 |廣西| 只看樓主 |倒序瀏覽 |閱讀模式
列表頁,搜索頁已經(jīng)修改成自定義頭像,內(nèi)容頁無從下手(代碼如下)
  1. <blockquote><span style="white-space: normal;"><span style="white-space:pre">        </span><div class="plc cl" id="pid$post['pid']"></span>
[backcolor=var(--vscode-textCodeBlock-background)]試試在<!--{if !$post['authorid'] || $post['anonymous']}-->判斷條件下,直接插入自定義的頭像URL
將下面的:https://www.72jz.com/logo.png 改成你的圖片url
    <div class="avatar">
        <img src="<!--{if !$post['authorid'] || $post['anonymous']}-->https://www.72jz.com/logo.png<!--{else}--><!--{avatar($post['authorid'], 'small', true)}--><!--{/if}-->" />
    </div>
    <div class="display pi<!--{if $post['first']}--> pione<!--{/if}-->">
        <ul class="authi">
            <li class="mtit">
                <span class="y">
                    <!--{if isset($post['isstick'])}-->
                        <img src="{IMGDIR}/settop.png" class="vm" /> {lang from} {$post['number']}{$postnostick}
                    <!--{elseif $post['number'] == -1}-->
                        {lang recommend_post}
                    <!--{else}-->
                        <!--{if !empty($postno[$post['number']])}-->$postno[$post['number']]<!--{else}-->{$post['number']}{$postno[0]}<!--{/if}-->
                    <!--{/if}-->
                </span>
                <span class="z">
                <!--{if $post['authorid'] && $post['username'] && !$post['anonymous']}-->
                    <a href="home.php?mod=space&uid=$post['authorid']">$post['author']</a>
                <!--{else}-->
                    <!--{if !$post['authorid']}-->
                    <a href="javascript:;">{lang guest} <em>$post['useip']{if $post['port']}:$post['port']{/if}</em></a>
                    <!--{elseif $post['authorid'] && $post['username'] && $post['anonymous']}-->
                    <!--{if $_G['forum']['ismoderator']}--><a href="home.php?mod=space&uid=$post['authorid']">{$_G['setting']['anonymoustext']}</a><!--{else}-->{$_G['setting']['anonymoustext']}<!--{/if}-->
                    <!--{else}-->
                    $post['author'] <em>{lang member_deleted}</em>
                    <!--{/if}-->
                <!--{/if}-->
                </span>
3 點
2 個
 樓主| 發(fā)表于 2024-11-19 22:48:46 |廣西| 只看Ta
(代碼如下)
                <div class="avatar"><img src="<!--{if !$post['authorid'] || $post['anonymous']}--><!--{avatar(0, 'small', true)}--><!--{else}--><!--{avatar($post['authorid'], 'small', true)}--><!--{/if}-->" /></div>
                        <ul class="authi">
                                <li class="mtit">
                                        <span class="y">
                                                        <img src ="{IMGDIR}/settop.png" class="vm" /> {lang from} {$post['number']}{$postnostick}
                                                <!--{else}-->
                                                <!--{/if}-->
                                        </span>
                                        <span class="z">
                                        <!--{else}-->
                                                <!--{else}-->
                                                <!--{/if}-->
                                        <!--{/if}-->
                                        </span>
7 點
9 個
發(fā)表于 2024-11-20 00:29:49 |安徽| 只看Ta
    </div>
        <ul class="authi">
            <li class="mtit">
                <span class="y">
                    <!--{else}-->
                    <!--{/if}-->
                </span>
                <span class="z">
                <!--{else}-->
                    <!--{else}-->
                    <!--{/if}-->
                <!--{/if}-->
                </span>
3 點
2 個
 樓主| 發(fā)表于 2024-11-20 02:01:07 |廣西| 只看Ta
bug八阿哥 發(fā)表于 2024-11-20 00:29
試試在判斷條件下,直接插入自定義的頭像URL
將下面的:https://www.72jz.com/logo.png 改成你的圖片url ...
好了  謝謝你
GMT+8, 2026-4-19 04:29 , Processed in 0.063125 second(s), 15 queries , Redis On.
