查看: 2124|回復(fù): 8
2024年進(jìn)入尾聲了,給論壇來個(gè)下雪的效果
145 點(diǎn)
90 個(gè)
發(fā)表于 2024-12-4 20:40:37 |馬來西亞| 只看樓主 |倒序?yàn)g覽 |閱讀模式
喜歡的可以把代碼復(fù)制黏貼到后臺(tái)\全局\第三方代碼框,里邊都是由兩個(gè)代碼組成,你也可以改成一個(gè)
1、雪花數(shù)量比較少的
  1. <script type='text/javascript' src='https://file.uhsea.com/2412/f8317aeca7ea952385d646ffb9d61de2XN.js?ver=1.5' id='jsnow-js'></script>
  2. <script type='text/javascript' id='snow-effect-js-extra'>
  3. /* <![CDATA[ */
  4. var snoweffect = {"show":"1","flakes_num":"30","falling_speed_min":"1","falling_speed_max":"3","flake_max_size":"20","flake_min_size":"10","vertical_size":"800","flake_color":"rgba(125,137,95,0.1),"flake_zindex":"100000","flake_type":"#10053","fade_away":"1"};
  5. /* ]]> */
  6. </script>
  7. <script type='text/javascript' src='https://file.uhsea.com/2412/6aa3c50309288463b854aa23913cc2bb6B.js?ver=1.0.0' id='snow-effect-js'></script>
  8. <script type='text/javascript' src='https://file.uhsea.com/2412/994f4f0712c9535affda3e97aed3999eRD.js?ver=1.0' id='snow-js-js'></script>
  9. <script type='text/javascript' id='snow-js-js-after'>
  10. (function( $ ) {
  11. var snowMax = 45;
  12. var snowColor = new Array("#aaaacc","#ddddff","#ccccdd","#f3f3f3","#f0ffff");
  13. var snowType = new Array("Times","Arial","Times","Verdana");
  14. var snowEntity = "*";
  15. var snowSpeed = 0.5;
  16. var snowMaxSize = 50;
  17. var snowMinSize = 22;
  18.                 var snowRefresh = 50;
  19.                 var snowZIndex = 2500;
  20.                 var snowStyles = "cursor: default; -webkit-user-select: none; -moz-user-select: none; -ms-user-select: none; -o-user-select: none; user-select: none;";
  21. jQuery(document).trigger( 'loadWPSnow', [ snowMax, snowColor, snowType, snowEntity, snowSpeed, snowMaxSize, snowMinSize, snowRefresh, snowZIndex, snowStyles ] );
  22. })( jQuery );
  23. </script>
  24. <!-- Snow Start -->
  25. <canvas id="Snow"></canvas>
  26. <script type='text/javascript' src='https://file.uhsea.com/2412/0f505f61089fb27b759c3d0ee8af68410J.js'></script>
  27. <style>#Snow{
  28.     position: fixed;
  29.     top: 0;
  30.     left: 0;
  31.     width: 100%;
  32.     height: 100%;
  33.     z-index: 99999;
  34.     //background: rgba(125,137,95,0.1);
  35.     pointer-events: none;
  36. }</style>
  37. <!-- Snow End -->
2、雪花數(shù)量比較多的
  3. /* <![CDATA[ */
  4. var snoweffect = {"show":"1","flakes_num":"30","falling_speed_min":"1","falling_speed_max":"3","flake_max_size":"20","flake_min_size":"10","vertical_size":"800","flake_color":"#efefef"flake_zindex":"100000","flake_type":"#10053","fade_away":"1"};
  5. /* ]]> */
  6. </script>
  22. })( jQuery );
  23. </script>
  26. <script type='text/javascript' src='https://file.uhsea.com/2412/e96ca38f855a468e7df5dab55cd695ceEU.js'></script>
  27. <style>#Snow{
  29.     top: 0;
  30.     left: 0;
  31.     width: 100%;
  32.     height: 100%;
  33.     z-index: 99999;
  36. }</style>
7 點(diǎn)
9 個(gè)
發(fā)表于 2024-12-5 10:49:32 |安徽| 只看Ta
占樓支持一下
16 點(diǎn)
8 個(gè)
發(fā)表于 2024-12-5 13:35:51 |海南| 只看Ta
感謝,收下了
14 個(gè)
發(fā)表于 2024-12-7 12:25:08 |福建| 只看Ta
學(xué)習(xí)收藏。。。。
發(fā)表于 2024-12-7 13:49:27 |浙江| 只看Ta
不錯(cuò),挺好用的。支持一下
發(fā)表于 2024-12-21 17:33:29 |江西來自手機(jī) | 只看Ta
支持老哥
7 個(gè)
發(fā)表于 2024-12-23 15:12:37 |福建| 只看Ta
支持
31 點(diǎn)
44 個(gè)
發(fā)表于 2025-1-4 00:04:50 |山東| 只看Ta
不錯(cuò),挺好玩的
5 點(diǎn)
4 個(gè)
發(fā)表于 2025-1-4 22:10:49 |河北| 只看Ta
感謝 非常實(shí)用
GMT+8, 2026-4-18 10:42 , Processed in 0.053035 second(s), 10 queries , Redis On.
