查看: 1181|回復(fù): 4
[求助] 安裝不了DZ3.5,我的是獨(dú)立數(shù)據(jù)庫,阿里云的2h2g
6 個(gè)
發(fā)表于 2025-1-8 13:29:05 |廣東| 只看樓主 |倒序?yàn)g覽 |閱讀模式
  1. 數(shù)據(jù)庫表創(chuàng)建完成
  2. 失敗
  3. Discuz! Database Error
  4. SQL:INSERT INTO pre_common_admingroup SET `admingid`='1',`alloweditpost`='1',`alloweditpoll`='1',`allowstickthread`='3',`allowmodpost`='1',`allowdelpost`='1',`allowmassprune`='1',`allowrefund`='1',`allowcensorword`='1',`allowviewip`='1',`allowbanip`='1',`allowedituser`='1',`allowmoduser`='1',`allowbanuser`='1',`allowbanvisituser`='1',`allowpostannounce`='1',`allowviewlog`='1',`allowbanpost`='1',`supe_allowpushthread`='1',`allowhighlightthread`='1',`allowlivethread`='1',`allowdigestthread`='3',`allowrecommendthread`='1',`allowbumpthread`='1',`allowclosethread`='1',`allowmovethread`='1',`allowedittypethread`='1',`allowstampthread`='1',`allowcopythread`='1',`allowmergethread`='1',`allowsplitthread`='1',`allowrepairthread`='1',`allowwarnpost`='1',`allowviewreport`='1',`alloweditforum`='1',`allowremovereward`='1',`allowedittrade`='1',`alloweditactivity`='1',`allowstickreply`='1',`allowmanagearticle`='1',`allowaddtopic`='1',`allowmanagetopic`='1',`allowdiy`='1',`allowclearrecycle`='1',`allowmanagetag`='1',`managefeed`='1',`managedoing`='1',`manageshare`='1',`manageblog`='1',`managealbum`='1',`managecomment`='1',`managemagiclog`='1',`managereport`='1',`managehotuser`='1',`managedefaultuser`='1',`managemagic`='1',`manageclick`='1',`allowstamplist`='1',`allowmanagecollection`='1',`allowmakehtml`='1'
  5. Error:Duplicate entry '1' for key 'PRIMARY'
  6. Errno:1062
  7. 您必須解決以上問題,安裝才可以繼續(xù)
  8. 正在初始化數(shù)據(jù)表中的數(shù)據(jù) pre_common_admingroup ... 失敗
  9. 您必須解決以上問題,安裝才可以繼續(xù)
配置環(huán)境是
PHP 7.4.33
系統(tǒng)是:系統(tǒng):Debian GNU/Linux 12 (bookworm) x86_64(Py3.7.16)
服務(wù)器是:2h2g
數(shù)據(jù)庫是獨(dú)立數(shù)據(jù)庫:5.7的  阿里云購買的數(shù)據(jù)庫
這里是php的設(shè)置
超市時(shí)間設(shè)置了86400
已經(jīng)重載了php 的配置,已經(jīng)重啟了php
還是一直安裝不了
18 點(diǎn)
13 個(gè)
發(fā)表于 2025-1-13 21:10:57 |廣東| 只看Ta
在本地win環(huán)境安裝下,然后再導(dǎo)入到線上數(shù)據(jù)庫。這樣更方便一點(diǎn)。
31 點(diǎn)
44 個(gè)
發(fā)表于 2025-1-13 22:09:24 |山東| 只看Ta
建議完全重新來一遍。
發(fā)表于 2025-1-14 13:50:04 |江蘇| 只看Ta
調(diào)整nginx的proxy超時(shí)時(shí)間
7 個(gè)
發(fā)表于 2025-1-14 14:17:11 |安徽| 只看Ta
dz3.4肯定能順利安裝,dz3.5需要更好的電腦配置
GMT+8, 2026-4-19 01:39 , Processed in 0.048828 second(s), 12 queries , Redis On.
