config.inc.php全部內(nèi)容如下:(以phpmyadmin2.5.4為例)
<?php
/* $Id: config.inc.php,v 1.204.2.1 2003/10/10 14:24:24 nijel Exp $ */
// vim: expandtab sw=4 ts=4 sts=4:
* phpMyAdmin Configuration File
* All directives are explained in Documentation.html
* Sets the php error reporting - Please do not change this line!
if (!isset($old_error_reporting)) {
error_reporting(E_ALL);
@ini_set('display_errors', '1');
* Your phpMyAdmin url
* Complete the variable below with the full url ie
* http://www.your_web.net/path_to_your_phpMyAdmin_directory/
* It must contain characters that are valid for a URL, and the path is
* case sensitive on some Web servers, for example Unix-based servers.
* In most cases you can leave this variable empty, as the correct value
* will be detected automatically. However, we recommend that you do
* test to see that the auto-detection code works in your system. A good
* test is to browse a table, then edit a row and save it. There will be
* an error message if phpMyAdmin cannot auto-detect the correct value.
* If the auto-detection code does work properly, you can set to TRUE the
* $cfg['PmaAbsoluteUri_DisableWarning'] variable below.
$cfg['PmaAbsoluteUri'] = '';-----這里設(shè)置你的phpmyadmin的URL,如:http://localhost/phpmyadmin/
* Disable the default warning about $cfg['PmaAbsoluteUri'] not being set
* You should use this if and ONLY if the PmaAbsoluteUri auto-detection
* works perfectly.
$cfg['PmaAbsoluteUri_DisableWarning'] = FALSE;
* Disable the default warning that is displayed on the DB Details Structure page if
* any of the required Tables for the relationfeatures could not be found
$cfg['PmaNoRelation_DisableWarning'] = FALSE;
* The 'cookie' auth_type uses blowfish algorithm to encrypt the password. If
* at least one server configuration uses 'cookie' auth_type, enter here a
* passphrase that will be used by blowfish.
$cfg['blowfish_secret'] = '';-----設(shè)定好root密碼后這里也要填寫
* Server(s) configuration
$i = 0;
// The $cfg['Servers'] array starts with $cfg['Servers'][1]. Do not use $cfg['Servers'][0].
// You can disable a server config entry by setting host to ''.
$i++;
$cfg['Servers'][$i]['host'] = 'localhost'; // MySQL hostname or IP address----這里可以設(shè)定遠程MySQL服務(wù)器IP地址
$cfg['Servers'][$i]['port'] = ''; // MySQL port - leave blank for default port-----默認為3306
$cfg['Servers'][$i]['socket'] = ''; // Path to the socket - leave blank for default socket
$cfg['Servers'][$i]['connect_type'] = 'tcp'; // How to connect to MySQL server ('tcp' or 'socket')-----連接MySQL服務(wù)器的方式
$cfg['Servers'][$i]['compress'] = FALSE; // Use compressed protocol for the MySQL connection
// (requires PHP >= 4.3.0)-----是否使用壓縮協(xié)議,PHP版本須>= 4.3.0
$cfg['Servers'][$i]['controluser'] = ''; // MySQL control user settings
// (this user must have read-only
$cfg['Servers'][$i]['controlpass'] = ''; // access to the "mysql/user"
// and "mysql/db" tables)-----MySQL控制用戶設(shè)定,該用戶只對mysql數(shù)據(jù)庫下的user和db表有完全權(quán)限
$cfg['Servers'][$i]['auth_type'] = 'config';
// Authentication method (config, http or cookie based)?-----如果PHP安裝模式為Apache,可以使用http和cookie;如果PHP安裝模式為CGI,可以使用cookie;默認為config,是不安全的,不推薦。
$cfg['Servers'][$i]['user'] = 'root'; // MySQL user-----MySQL連接用戶
$cfg['Servers'][$i]['password'] = '';
// MySQL password (only needed with 'config' auth_type)-----MySQL連接密碼,建議在安裝好PHP和MySQL后,先用phpmyadmin設(shè)定root密碼,然后在這里填寫
$cfg['Servers'][$i]['only_db'] = ''; // If set to a db-name, only
// this db is displayed
// at left frame
// It may also be an array
// of db-names-----如果在這里設(shè)定一個數(shù)據(jù)庫的名字,那么登陸后框架左邊將只顯示這個數(shù)據(jù)庫
$cfg['Servers'][$i]['verbose'] = ''; // Verbose name for this host - leave blank to show the hostname
$cfg['Servers'][$i]['pmadb'] = ''; // Database used for Relation, Bookmark and PDF Features
// (see scripts/create_tables.sql)
// - leave blank for no support
// DEFAULT: 'phpmyadmin'
$cfg['Servers'][$i]['bookmarktable'] = ''; // Bookmark table
// - leave blank for no bookmark support
// DEFAULT: 'pma_bookmark'
$cfg['Servers'][$i]['relation'] = ''; // table to describe the relation between links (see doc)
// - leave blank for no relation-links support
// DEFAULT: 'pma_relation'
$cfg['Servers'][$i]['table_info'] = ''; // table to describe the display fields
// - leave blank for no display fields support
// DEFAULT: 'pma_table_info'
$cfg['Servers'][$i]['table_coords'] = ''; // table to describe the tables position for the PDF schema
// - leave blank for no PDF schema support
// DEFAULT: 'pma_table_coords'
$cfg['Servers'][$i]['pdf_pages'] = ''; // table to describe pages of relationpdf
// - leave blank if you don't want to use this
// DEFAULT: 'pma_pdf_pages'
$cfg['Servers'][$i]['column_info'] = ''; // table to store column information
// - leave blank for no column comments/mime types
// DEFAULT: 'pma_column_info'
$cfg['Servers'][$i]['history'] = ''; // table to store SQL history
// - leave blank for no SQL query history
// DEFAULT: 'pma_history'
$cfg['Servers'][$i]['verbose_check'] = TRUE; // set to FALSE if you know that your pma_* tables
// are up to date. This prevents compatibility
// checks and thereby increases performance.
$cfg['Servers'][$i]['AllowDeny']['order'] // Host authentication order, leave blank to not use
$cfg['Servers'][$i]['AllowDeny']['rules'] // Host authentication rules, leave blank for defaults
= array();
$i++;
$cfg['Servers'][$i]['host'] = '';
$cfg['Servers'][$i]['pmadb'] = ''; // 'phpmyadmin' - see scripts/create_tables.sql
$cfg['Servers'][$i]['bookmarktable'] = ''; // 'pma_bookmark'
$cfg['Servers'][$i]['relation'] = ''; // 'pma_relation'
$cfg['Servers'][$i]['table_info'] = ''; // 'pma_table_info'
$cfg['Servers'][$i]['table_coords'] = ''; // 'pma_table_coords'
$cfg['Servers'][$i]['pdf_pages'] = ''; // 'pma_pdf_pages'
$cfg['Servers'][$i]['column_info'] = ''; // 'pma_column_info'
$cfg['Servers'][$i]['history'] = ''; // 'pma_history'
= array();
$i++;
= array();
// If you have more than one server configured, you can set $cfg['ServerDefault']
// to any one of them to autoconnect to that server when phpMyAdmin is started,
// or set it to 0 to be given a list of servers without logging in
// If you have only one server configured, $cfg['ServerDefault'] *MUST* be
// set to that server.[color]=red]-----是否顯示所有的MySQL服務(wù)器
$cfg['ServerDefault'] = 1; // Default server (0 = no default server)
$cfg['Server'] = '';
unset($cfg['Servers'][0]);
* Other core phpMyAdmin settings
$cfg['OBGzip'] = 'auto'; // use GZIP output buffering if possible (TRUE|FALSE|'auto')-----有必要的話是否使用GZIP輸出緩沖
$cfg['PersistentConnections'] = FALSE; // use persistent connections to MySQL database-----是否使用MySQL持久連接,即pconnect
$cfg['ExecTimeLimit'] = 300; // maximum execution time in seconds (0 for no limit)-----最大腳本執(zhí)行時間,單位:秒
$cfg['SkipLockedTables'] = FALSE; // mark used tables, make possible to show
// locked tables (since MySQL 3.23.30)
$cfg['ShowSQL'] = TRUE; // show SQL queries as run-----運行查詢時顯示SQL查詢語句
$cfg['AllowUserDropDatabase'] = FALSE; // show a 'Drop database' link to normal users-----是否對普通用戶顯示“刪除數(shù)據(jù)庫”連接
$cfg['Confirm'] = TRUE; // confirm 'DROP TABLE' & 'DROP DATABASE'-----刪除數(shù)據(jù)表/庫前是否出現(xiàn)確認提示框
$cfg['LoginCookieRecall'] = TRUE; // recall previous login in cookie auth. mode or not-----是否收回先前cookie認證模式的cookie
$cfg['UseDbSearch'] = TRUE; // whether to enable the "database search" feature
// or not
$cfg['IgnoreMultiSubmitErrors'] = FALSE; // if set to true, PMA continues computing multiple-statement queries
// even if one of the queries failed
$cfg['VerboseMultiSubmit'] = TRUE; // if set to true, PMA will show the affected rows of EACH statement on
// multiple-statement queries. See the read_dump.php file for hardcoded
// defaults on how many queries a statement may contain!
$cfg['AllowArbitraryServer'] = FALSE; // allow login to any user entered server in cookie based auth
// Left frame setup-----左側(cè)框架設(shè)置
$cfg['LeftFrameLight'] = TRUE; .-----是否使用下拉框顯示當前數(shù)據(jù)庫// use a select-based menu and display only the
// current tables in the left frame
$cfg['LeftFrameTableSeparator']= '__'; // Which string will be used to generate table prefixes
// to split tables into multiple categories
$cfg['LeftFrameTableLevel'] = '1'; // How many sublevels should be displayed when splitting
// up tables by the above Separator
$cfg['ShowTooltip'] = TRUE; // display table comment as tooltip in left frame-----是否在框架左側(cè)顯示數(shù)據(jù)表內(nèi)容提示
$cfg['ShowTooltipAliasDB'] = FALSE; // if ShowToolTip is enabled, this defines that table/db comments
$cfg['ShowTooltipAliasTB'] = FALSE; // are shown (in the left menu and db_details_structure) instead of
// table/db names
$cfg['LeftDisplayLogo'] = TRUE; // display logo at top of left frame-----是否在框架左側(cè)顯示phpmyadmin的logo
$cfg['LeftDisplayServers'] = FALSE; // display server choice at top of left frame-----是否顯示MySQL服務(wù)器選擇選項
// In the main frame, at startup...-----右側(cè)主框架設(shè)置(剛進入時)
$cfg['ShowStats'] = TRUE; // allow to display statistics and space usage in
// the pages about database details and table
// properties
$cfg['ShowMysqlInfo'] = FALSE; -----是否顯示MySQL運行時間// whether to display the "MySQL runtime
$cfg['ShowMysqlVars'] = FALSE; -----是否顯示MySQL系統(tǒng)變量// information", "MySQL system variables", "PHP
$cfg['ShowPhpInfo'] = FALSE; -----是否顯示PHP信息// information" and "change password" links for
$cfg['ShowChgPassword'] = FALSE; -----修改密碼選項// simple users or not
$cfg['SuggestDBName'] = TRUE; -----是否顯示要建立的數(shù)據(jù)庫默認名字// suggest a new DB name if possible (false = keep empty)
// In browse mode...
$cfg['ShowBlob'] = FALSE; // display blob field contents
$cfg['NavigationBarIconic'] = TRUE; // do not display text inside navigation bar buttons
$cfg['ShowAll'] = FALSE; // allows to display all the rows-----是否顯示所有數(shù)據(jù)表行
$cfg['MaxRows'] = 30; // maximum number of rows to display-----數(shù)據(jù)表行每頁顯示的數(shù)量
$cfg['Order'] = 'ASC'; // default for 'ORDER BY' clause (valid
// values are 'ASC', 'DESC' or 'SMART' -ie
// descending order for fields of type
// TIME, DATE, DATETIME & TIMESTAMP,
// ascending order else-)
// In edit mode...
$cfg['ProtectBinary'] = 'blob'; // disallow editing of binary fields
// valid values are:
// FALSE allow editing
// 'blob' allow editing except for BLOB fields
// 'all' disallow editing
$cfg['ShowFunctionFields'] = TRUE; // Display the function fields in edit/insert mode
$cfg['CharEditing'] = 'input';
// Which editor should be used for CHAR/VARCHAR fields:
// input - allows limiting of input length
// textarea - allows newlines in fields
// For the export features...
$cfg['ZipDump'] = TRUE; // Allow the use of zip/gzip/bzip
$cfg['GZipDump'] = TRUE; // compression for
$cfg['BZipDump'] = TRUE; // dump files
$cfg['CompressOnFly'] = TRUE; // Will compress gzip/bzip2 exports on
// fly without need for much memory.
// If you encounter problems with
// created gzip/bzip2 files disable
// this feature.
// Tabs display settings
$cfg['LightTabs'] = FALSE; // use graphically less intense menu tabs
$cfg['PropertiesIconic'] = TRUE; // Use icons instead of text for the table display of a database (TRUE|FALSE|'both')
$cfg['PropertiesNumColumns'] = 1; // How many columns should be used for table display of a database?
// (a value larger than 1 results in some information being hidden)
$cfg['DefaultTabServer'] = 'main.php';
// Possible values:
// 'main.php' = the welcome page
// (recommended for multiuser setups)
// 'server_databases.php' = list of databases
// 'server_status.php' = runtime information
// 'server_variables.php' = MySQL server variables
// 'server_privileges.php' = user management
// 'server_processlist.php' = process list
$cfg['DefaultTabDatabase'] = 'db_details_structure.php';
// Possible values:
// 'db_details_structure.php' = tables list
// 'db_details.php' = sql form
// 'db_search.php' = search query
$cfg['DefaultTabTable'] = 'tbl_properties_structure.php';
// Possible values:
// 'tbl_properties_structure.php' = fields list
// 'tbl_properties.php' = sql form
// 'tbl_select.php = select page
// 'tbl_change.php = insert row page
* Export defaults
$cfg['Export']['format'] = 'sql'; // sql/latex/excel/csv/xml-----導出文件的格式
$cfg['Export']['compression'] = 'none'; // none/zip/gzip/bzip2-----到處文件是否壓縮
$cfg['Export']['asfile'] = FALSE;----是否導出為文件
$cfg['Export']['onserver'] = FALSE;-----導出到服務(wù)器
$cfg['Export']['onserver_overwrite'] = FALSE;-----是否使用導出覆蓋
$cfg['Export']['remember_file_template'] = TRUE;-----記住文件模板
$cfg['Export']['csv_columns'] = FALSE;
$cfg['Export']['csv_null'] = 'NULL';
$cfg['Export']['csv_separator'] = ';';
$cfg['Export']['csv_enclosed'] = '"';
$cfg['Export']['csv_escaped'] = '\\';
$cfg['Export']['csv_terminated'] = 'AUTO';
$cfg['Export']['excel_columns'] = FALSE;
$cfg['Export']['excel_null'] = 'NULL';
$cfg['Export']['latex_structure'] = TRUE;
$cfg['Export']['latex_data'] = TRUE;
$cfg['Export']['latex_columns'] = TRUE;
$cfg['Export']['latex_relation'] = TRUE;
$cfg['Export']['latex_comments'] = TRUE;
$cfg['Export']['latex_mime'] = TRUE;
$cfg['Export']['latex_null'] = '\textit{NULL}';
$cfg['Export']['latex_caption'] = TRUE;
$cfg['Export']['latex_data_label'] = 'tab:__TABLE__-data';
$cfg['Export']['latex_structure_label'] = 'tab:__TABLE__-structure';
$cfg['Export']['sql_structure'] = TRUE;
$cfg['Export']['sql_data'] = TRUE;
$cfg['Export']['sql_drop_database'] = FALSE;
$cfg['Export']['sql_drop_table'] = FALSE;
$cfg['Export']['sql_auto_increment'] = TRUE;
$cfg['Export']['sql_backquotes'] = TRUE;
$cfg['Export']['sql_relation'] = FALSE;
$cfg['Export']['sql_columns'] = FALSE;
$cfg['Export']['sql_extended'] = FALSE;
$cfg['Export']['sql_comments'] = FALSE;
$cfg['Export']['sql_mime'] = FALSE;
* Link to the official MySQL documentation.
* Be sure to include no trailing slash on the path.
* See http://www.mysql.com/documentation/index.html for more information
* about MySQL manuals and their types.
$cfg['MySQLManualBase'] = 'http://www.mysql.com/doc/en';-----MySQL在線手冊地址
* Type of MySQL documentation:
* old - old style used in phpMyAdmin 2.3.0 and sooner
* searchable - "Searchable, with user comments"
* chapters - "HTML, one page per chapter"
* big - "HTML, all on one page"
* none - do not show documentation links
$cfg['MySQLManualType'] = 'searchable';
* PDF options
$cfg['PDFPageSizes'] = array('A3', 'A4', 'A5', 'letter', 'legal');
$cfg['PDFDefaultPageSize'] = 'A4';-----PDF頁默認大小
* Language and charset conversion settings
// Default language to use, if not browser-defined or user-defined
$cfg['DefaultLang'] = 'en-iso-8859-1';-----如果想使phpmyadmin直接顯示中文,這里填:zh
// Force: always use this language - must be defined in
// libraries/select_lang.lib.php
// $cfg['Lang'] = 'en-iso-8859-1';
// Default charset to use for recoding of MySQL queries, does not take
// any effect when charsets recoding is switched off by
// $cfg['AllowAnywhereRecoding'] or in language file
// (see $cfg['AvailableCharsets'] to possible choices, you can add your own)
$cfg['DefaultCharset'] = 'iso-8859-1';-----默認的phpmyadmin語言,可設(shè)置為:gb2312
// Allow charset recoding of MySQL queries, must be also enabled in language
// file to make harder using other language files than unicode.
// Default value is FALSE to avoid problems on servers without the iconv
// extension and where dl() is not supported
$cfg['AllowAnywhereRecoding'] = FALSE;
// You can select here which functions will be used for charset conversion.
// Possible values are:
// auto - automatically use available one (first is tested iconv, then
// recode)
// iconv - use iconv or libiconv functions
// recode - use recode_string function
$cfg['RecodingEngine'] = 'auto';
// Specify some parameters for iconv used in charset conversion. See iconv
// documentation for details:
// http://www.gnu.org/software/libi ... v/iconv_open.3.html
$cfg['IconvExtraParams'] = '';
// Available charsets for MySQL conversion. currently contains all which could
// be found in lang/* files and few more.
// Charsets will be shown in same order as here listed, so if you frequently
// use some of these move them to the top.
$cfg['AvailableCharsets'] = array(
'iso-8859-1',
'iso-8859-2',
'iso-8859-3',
'iso-8859-4',
'iso-8859-5',
'iso-8859-6',
'iso-8859-7',
'iso-8859-8',
'iso-8859-9',
'iso-8859-10',
'iso-8859-11',
'iso-8859-12',
'iso-8859-13',
'iso-8859-14',
'iso-8859-15',
'windows-1250',
'windows-1251',
'windows-1252',
'windows-1257',
'koi8-r',
'big5',
'gb2312',
'utf-8',
'utf-7',
'x-user-defined',
'euc-jp',
'ks_c_5601-1987',
'tis-620',
'SHIFT_JIS'
// Loads language file
require('./libraries/select_lang.lib.php');
* Customization & design -----頁面格式設(shè)定,以內(nèi)容較多,可自行根據(jù)注釋詳細設(shè)定,這里給出部分注釋
$cfg['LeftWidth'] = 150; // left frame width-----左側(cè)框架寬度
$cfg['LeftBgColor'] = '#D0DCE0'; // background color for the left frame-----框架左側(cè)的背景顏色
$cfg['RightBgColor'] = '#F5F5F5'; // background color for the right frame-----框架右側(cè)的背景顏色
$cfg['RightBgImage'] = ''; // path to a background image for the right frame-----框架右側(cè)的背景圖片地址,不使用背景圖片請留空
// (leave blank for no background image)
$cfg['LeftPointerColor'] = '#CCFFCC'; // color of the pointer in left frame
// (blank for no pointer)-----框架左側(cè)的指向點顏色
$cfg['Border'] = 0; // border width on tables-----表格寬度
$cfg['ThBgcolor'] = '#D3DCE3'; // table header row colour-----表格頭顏色
$cfg['BgcolorOne'] = '#CCCCCC'; // table data row colour-----表格中數(shù)據(jù)所在行的顏色
$cfg['BgcolorTwo'] = '#DDDDDD'; // table data row colour, alternate-----表格中數(shù)據(jù)所在行的交替顏色
$cfg['BrowsePointerColor'] = '#CCFFCC'; // color of the pointer in browse mode
$cfg['BrowseMarkerColor'] = '#FFCC99'; // color of the marker (visually marks row
// by clicking on it) in browse mode
// (blank for no marker)
$cfg['TextareaCols'] = 40; // textarea size (columns) in edit mode
// (this value will be emphasized (*2) for sql
// query textareas and (*1.25) for query window)
$cfg['TextareaRows'] = 7; // textarea size (rows) in edit mode
$cfg['LongtextDoubleTextarea'] = TRUE; // double size of textarea size for longtext fields
$cfg['TextareaAutoSelect'] = TRUE; // autoselect when clicking in the textarea of the querybox
$cfg['CharTextareaCols'] = 40; // textarea size (columns) for CHAR/VARCHAR
$cfg['CharTextareaRows'] = 2; // textarea size (rows) for CHAR/VARCHAR
$cfg['CtrlArrowsMoving'] = TRUE; // Enable Ctrl+Arrows moving between fields when editing?
$cfg['LimitChars'] = 50; // Max field data length in browse mode for all non-numeric fields
$cfg['ModifyDeleteAtLeft'] = TRUE; // show edit/delete links on left side of browse
// (or at the top with vertical browse)
$cfg['ModifyDeleteAtRight'] = FALSE; // show edit/delete links on right side of browse
// (or at the bottom with vertical browse)
$cfg['DefaultDisplay'] = 'horizontal'; // default display direction
// (horizontal|vertical|horizontalflipped)
$cfg['DefaultPropDisplay'] = 'horizontal'; // default display direction for altering/
// creating columns (tbl_properties)
// (horizontal|vertical)
$cfg['HeaderFlipType'] = 'css'; // table-header rotation via faking or css? (css|fake)
// NOTE: CSS only works in IE browsers!
$cfg['ShowBrowseComments'] = TRUE; // shows stored relation-comments in 'browse' mode.
$cfg['ShowPropertyComments']= TRUE; // shows stored relation-comments in 'table property' mode.
$cfg['RepeatCells'] = 100; // repeat header names every X cells? (0 = deactivate)
$cfg['QueryFrame'] = TRUE; // displays a new frame where a link to a querybox is always displayed.
$cfg['QueryFrameJS'] = TRUE; // whether to use JavaScript functions for opening a new window for SQL commands.
// if set to 'false', the target of the querybox is always the right frame.
$cfg['QueryFrameDebug'] = FALSE; // display JS debugging link (DEVELOPERS only)
$cfg['QueryWindowWidth'] = 550; // Width of Query window
$cfg['QueryWindowHeight'] = 310; // Height of Query window
$cfg['QueryHistoryDB'] = FALSE; // Set to TRUE if you want DB-based query history.
// If FALSE, this utilizes JS-routines to display
// query history (lost by window close)
$cfg['QueryWindowDefTab'] = 'sql'; // which tab to display in the querywindow on startup
// (sql|files|history|full)
$cfg['QueryHistoryMax'] = 25; // When using DB-based query history, how many entries
// should be kept?
$cfg['BrowseMIME'] = TRUE; // Use MIME-Types (stored in column comments table) for
$cfg['MaxExactCount'] = 20000; // When approximate count < this, PMA will get exact count for
// table rows.
$cfg['WYSIWYG-PDF'] = TRUE; // Utilize DHTML/JS capabilities to allow WYSIWYG editing of
// the PDF page editor. Requires an IE6/Mozilla based browser.
* SQL Query box settings
* These are the links display in all of the SQL Query boxes
$cfg['SQLQuery']['Edit'] = TRUE; // Edit link to change a query
$cfg['SQLQuery']['Explain'] = TRUE; // EXPLAIN on SELECT queries
$cfg['SQLQuery']['ShowAsPHP'] = TRUE; // Wrap a query in PHP
$cfg['SQLQuery']['Validate'] = FALSE; // Validate a query (see $cfg['SQLValidator'] as well)
* Webserver upload/save/import directories
$cfg['UploadDir'] = ''; // Directory for uploaded files that can be executed by
// phpMyAdmin. For example './upload'. Leave empty for
// no upload directory support
$cfg['SaveDir'] = ''; // Directory where phpMyAdmin can save exported data on
// server. For example './save'. Leave empty for no save
// directory support.
$cfg['docSQLDir'] = ''; // Directory for docSQL imports, phpMyAdmin can import
// docSQL files from that directory. For example
// './docSQL'. Leave empty for no docSQL import support.
* Misc. settings
$cfg['GD2Available'] = 'auto'; // Is GD >= 2 available? Set to yes/no/auto. 'auto'
// does autodetection, which is a bit expensive for
// php < 4.3.0, but it is the only safe vay how to
// determine GD version.
* SQL Parser Settings
]$cfg['SQP']['fmtType'] = 'html'; // 查詢語句輸出樣式 (html, text, none)
$cfg['SQP']['fmtInd'] = '1'; // 每行間距(floats ok)
$cfg['SQP']['fmtIndUnit'] = 'em'; // 每行的縮進單位 (CSS Types - {em,px,pt})
$cfg['SQP']['fmtColor'] = array( // 語法顏色數(shù)據(jù)
'comment' => '#808000',
'comment_mysql' => '',
'comment_ansi' => '',
'comment_c' => '',
'digit' => '',
'digit_hex' => 'teal',
'digit_integer' => 'teal',
'digit_float' => 'aqua',
'punct' => 'fuchsia',
'alpha' => '',
'alpha_columnType' => '#FF9900',
'alpha_columnAttrib' => '#0000FF',
'alpha_reservedWord' => '#990099',
'alpha_functionName' => '#FF0000',
'alpha_identifier' => 'black',
'alpha_variable' => '#800000',
'quote' => '#008000',
'quote_double' => '',
'quote_single' => '',
'quote_backtick' => ''
* If you wish to use the SQL Validator service, you should be
* aware of the following:
* All SQL statements are stored anonymously for statistical purposes.
* Mimer SQL Validator, Copyright 2002 Upright Database Technology.
* All rights reserved.
$cfg['SQLValidator']['use'] = FALSE; // Make the SQL Validator available
$cfg['SQLValidator']['username'] = ''; // If you have a custom username, specify it here (defaults to anonymous)
$cfg['SQLValidator']['password'] = ''; // Password for username
* Developers ONLY!
* To use the following, please install the DBG extension from http://dd.cron.ru/dbg/
$cfg['DBG']['enable'] = FALSE; // Make the DBG stuff available
$cfg['DBG']['profile']['enable'] = FALSE; // Produce profiling results of PHP
$cfg['DBG']['profile']['threshold'] = 0.5; // Threshold of long running code to display
// Anything below the threshold is not displayed
* MySQL settings
// Column types;
// varchar, tinyint, text and date are listed first, based on estimated popularity
$cfg['ColumnTypes'] = array(
'VARCHAR',
'TINYINT',
'TEXT',
'DATE',
'SMALLINT',
'MEDIUMINT',
'INT',
'BIGINT',
'FLOAT',
'DOUBLE',
'DECIMAL',
'DATETIME',
'TIMESTAMP',
'TIME',
'YEAR',
'CHAR',
'TINYBLOB',
'TINYTEXT',
'BLOB',
'MEDIUMBLOB',
'MEDIUMTEXT',
'LONGBLOB',
'LONGTEXT',
'ENUM',
'SET'
// Atributes
$cfg['AttributeTypes'] = array(
'BINARY',
'UNSIGNED',
'UNSIGNED ZEROFILL'
// Available functions
if ($cfg['ShowFunctionFields']) {
$cfg['Functions'] = array(
'ASCII',
'CHAR',
'SOUNDEX',
'LCASE',
'UCASE',
'NOW',
'PASSWORD',
'MD5',
'ENCRYPT',
'RAND',
'LAST_INSERT_ID',
'COUNT',
'AVG',
'SUM',
'CURDATE',
'CURTIME',
'FROM_DAYS',
'FROM_UNIXTIME',
'PERIOD_ADD',
'PERIOD_DIFF',
'TO_DAYS',
'UNIX_TIMESTAMP',
'USER',
'WEEKDAY',
'CONCAT'
// Which column types will be mapped to which Group?
$cfg['RestrictColumnTypes'] = array(
'VARCHAR' => 'FUNC_CHAR',
'TINYINT' => 'FUNC_NUMBER',
'TEXT' => 'FUNC_CHAR',
'DATE' => 'FUNC_DATE',
'SMALLINT' => 'FUNC_NUMBER',
'MEDIUMINT' => 'FUNC_NUMBER',
'INT' => 'FUNC_NUMBER',
'BIGINT' => 'FUNC_NUMBER',
'FLOAT' => 'FUNC_NUMBER',
'DOUBLE' => 'FUNC_NUMBER',
'DECIMAL' => 'FUNC_NUMBER',
'DATETIME' => 'FUNC_DATE',
'TIMESTAMP' => 'FUNC_DATE',
'TIME' => 'FUNC_DATE',
'YEAR' => 'FUNC_DATE',
'CHAR' => 'FUNC_CHAR',
'TINYBLOB' => 'FUNC_CHAR',
'TINYTEXT' => 'FUNC_CHAR',
'BLOB' => 'FUNC_CHAR',
'MEDIUMBLOB' => 'FUNC_CHAR',
'MEDIUMTEXT' => 'FUNC_CHAR',
'LONGBLOB' => 'FUNC_CHAR',
'LONGTEXT' => 'FUNC_CHAR',
'ENUM' => '',
'SET' => ''
// Map above defined groups to any function
$cfg['RestrictFunctions'] = array(
'FUNC_CHAR' => array(
'ASCII',
'CHAR',
'SOUNDEX',
'LCASE',
'UCASE',
'PASSWORD',
'MD5',
'ENCRYPT',
'LAST_INSERT_ID',
'USER',
'CONCAT'
'FUNC_DATE' => array(
'NOW',
'CURDATE',
'CURTIME',
'FROM_DAYS',
'FROM_UNIXTIME',
'PERIOD_ADD',
'PERIOD_DIFF',
'TO_DAYS',
'UNIX_TIMESTAMP',
'WEEKDAY'
'FUNC_NUMBER' => array(
'ASCII',
'CHAR',
'MD5',
'ENCRYPT',
'RAND',
'LAST_INSERT_ID',
'COUNT',
'AVG',
'SUM'
} // end if
* Unset magic_quotes_runtime - do not change!
set_magic_quotes_runtime(0);
* File Revision - do not change either!
$cfg['FileRevision'] = '$Revision: 1.204.2.1 $';
[ Last edited by yecoo on 2004-3-18 at 09:04 PM ] |
