查看: 8663|回復(fù): 3
[求助] 這種數(shù)據(jù)庫錯(cuò)誤
發(fā)表于 2020-12-12 11:52:59 |廣西| 只看樓主 |倒序?yàn)g覽 |閱讀模式
Discuz! Database Error
(1146) Table 's7072573.common_syscache' doesn't exist
SELECT * FROM common_syscache WHERE `cname` IN('userapp','portalcategory','diytemplatenameportal','setting','style_default','cronnextrun')
PHP Debug
No.        File        Line        Code
1        portal.php        18        discuz_application->init()
2        source/class/discuz/discuz_application.php        66        discuz_application->_init_setting()
3        source/class/discuz/discuz_application.php        686        loadcache(Array)
4        source/function/function_core.php        702        table_common_syscache->fetch_all(Array)
5        source/class/table/table_common_syscache.php        63        discuz_database::query(%s)
6        source/class/discuz/discuz_database.php        136        db_driver_mysql->query(%s, false, false)
7        source/class/db/db_driver_mysql.php        153        db_driver_mysql->halt(%s, %d, %s)
8        source/class/db/db_driver_mysql.php        224        break()
28580 個(gè)
發(fā)表于 2020-12-12 12:00:13 |浙江| 只看Ta
安裝不完整或其他誤操作導(dǎo)致數(shù)據(jù)表common_syscache不存在,請補(bǔ)齊缺失的數(shù)據(jù)表
629 個(gè)
發(fā)表于 2020-12-14 00:24:11 |福建| 只看Ta
系統(tǒng)緩存表不存在 如果是搬家 那就是庫不全 如果是新安裝 那就是沒安裝成功 檢查下哦
發(fā)表于 2020-12-16 16:40:37 |浙江| 只看Ta
common_syscache 數(shù)據(jù)庫表有問題
GMT+8, 2026-4-19 04:29 , Processed in 0.050185 second(s), 21 queries , Redis On.
