查看: 4183|回復(fù): 8
[已處理] 使用道具改名卡后,ucenter里名字改成功了,也可以用改后的名字登錄了,但是論壇里的名字還是沒變,請(qǐng)問如何處理?
3 個(gè)
發(fā)表于 2023-3-16 20:16:05 |陜西| 只看樓主 |倒序?yàn)g覽 |閱讀模式
瀏覽器: IE10 IE11 IE12 FireFox Chrome 其他(請(qǐng)?jiān)谔又性敿?xì)說明瀏覽器)
/home.php?mod=magic
/source/class/magic/magic_chgusername.php
  1. <?php
  2. /**
  3. *      [Discuz!] (C)2001-2099 Comsenz Inc.
  4. *      This is NOT a freeware, use is subject to license terms
  5. *
  6. *      $Id: magic_chgusername.php 2248 2020-02-16 00:00:00Z community $
  7. */
  8. if(!defined('IN_DISCUZ')) {
  9.         exit('Access Denied');
  10. }
  11. class magic_chgusername {
  12.         var $version = '1.0';
  13.         var $name = 'chgusername_name';
  14.         var $description = 'chgusername_desc';
  15.         var $price = '10';
  16.         var $weight = '10';
  17.         var $useevent = 1;
  18.         var $targetgroupperm = true;
  19.         var $copyright = '<a  target="_blank">Discuz! Community Team</a>';
  20.         var $magic = array();
  21.         var $parameters = array();
  22.         function getsetting(&$magic) {
  23.         }
  24.         function setsetting(&$magicnew, &$parameters) {
  25.         }
  26.         function usesubmit() {
  27.                 global $_G;
  28.                 if(empty($_GET['newusername'])) {
  29.                         showmessage(lang('magic/chgusername', 'chgusername_info_nonexistence'));
  30.                 }
  31.                 $censorexp = '/^('.str_replace(array('\\*', "\r\n", ' '), array('.*', '|', ''), preg_quote(($_G['settting']['censoruser'] = trim($_G['settting']['censoruser'])), '/')).')$/i';
  32.                 if($_G['settting']['censoruser'] && @preg_match($censorexp, $_GET['newusername'])) {
  33.                         showmessage(lang('magic/chgusername', 'chgusername_name_badword'));
  34.                 }
  35.                 loaducenter();
  36.                 $ucresult = uc_user_chgusername($_G['uid'], addslashes(trim($_GET['newusername'])));
  37.                 if($ucresult < 0) {
  38.                         if($ucresult == -1) {
  39.                                 showmessage(lang('magic/chgusername', 'chgusername_check_failed'));
  40.                         } elseif($ucresult == -2) {
  41.                                 showmessage(lang('magic/chgusername', 'chgusername_name_badword'));
  42.                         } elseif($ucresult == -3) {
  43.                                 showmessage(lang('magic/chgusername', 'chgusername_name_exists'));
  44.                         } else {
  45.                                 showmessage(lang('magic/chgusername', 'chgusername_change_failed'));
  46.                         }
  47.                 }
  48.                 usemagic($this->magic['magicid'], $this->magic['num']);
  49.                 updatemagiclog($this->magic['magicid'], '2', '1', '0', 0, 'uid', $_G['uid']);
  50.                 showmessage(lang('magic/chgusername', 'chgusername_change_success'), '', '', array('alert' => 'info', 'showdialog' => 1));
  51.         }
  52.         function show() {
  53.                 magicshowtype('top');
  54.                 magicshowsetting(lang('magic/chgusername', 'chgusername_newusername'), 'newusername', '', 'text');
  55.                 magicshowtype('bottom');
  56.         }
  57. }
  58. ?>
1 貢獻(xiàn)+1 金幣
小花 發(fā)表于 2023-4-28 14:39
UC通信是正常的  改名無效
X3.5的UC通信是雙向的,注意看DZ-》UC是否成功
發(fā)表于 2023-3-16 20:38:53 |浙江| 只看Ta
看看UC通信成功與否,再看看UC通知列表里通知是否成功
3 個(gè)
 樓主| 發(fā)表于 2023-3-17 20:15:28 |陜西| 只看Ta
接口通信沒有問題,顯示的是綠色對(duì)號(hào)
發(fā)表于 2023-3-18 09:18:35 |浙江| 只看Ta
bobbsh 發(fā)表于 2023-3-17 20:15
UC后臺(tái)通知列表里去看看通知情況
頭像被屏蔽
禁止發(fā)言
發(fā)表于 2023-3-29 23:25:39 |廣東| 只看Ta
4 個(gè)
發(fā)表于 2023-4-27 14:42:19 |安徽| 只看Ta
沒辦法 是3.5的bug
官方有償服務(wù)QQ 1453650
180 點(diǎn)
240005 個(gè)
發(fā)表于 2023-4-27 21:15:54 |浙江| 只看Ta
官方自帶的改名功能,是需要UC通信正常的,通信失敗就會(huì)導(dǎo)致UC的改名通知沒發(fā)送到論壇,從而導(dǎo)致論壇用戶名沒變。想要簡(jiǎn)單粗暴直接改數(shù)據(jù)庫(kù)里的用戶名的,可以應(yīng)用中心安裝免費(fèi)的改名道具:
https://addon.dismall.com/?ac=se ... =%E6%94%B9%E5%90%8D
4 個(gè)
發(fā)表于 2023-4-28 14:39:25 |安徽| 只看Ta
Discuz有償服務(wù) 發(fā)表于 2023-4-27 21:15
官方自帶的改名功能,是需要UC通信正常的,通信失敗就會(huì)導(dǎo)致UC的改名通知沒發(fā)送到論壇,從而導(dǎo)致論壇用戶 ...
UC通信是正常的  改名無效
發(fā)表于 2023-4-28 21:04:25 |浙江| 只看Ta
UC通信是正常的  改名無效
GMT+8, 2026-4-18 02:55 , Processed in 0.060744 second(s), 16 queries , Redis On.
