查看: 3103|回復(fù): 11
[已解決] X3.5帖子中的圖片,鼠標(biāo)指到圖片時提醒“下載附件”,如何去掉這個提示
48
21 個
發(fā)表于 2024-6-19 10:05:11 |廣東| 只看樓主 |倒序瀏覽 |閱讀模式
X3.5帖子中插入的圖片,當(dāng)鼠標(biāo)經(jīng)過指到圖片時,提醒“下載附件”以及上傳時間等,如何去除文字提醒?如下圖所示:
X3.4版本是修改template/default/forum/discuzcode.htm文件,查找第258行,源代碼如下:
  1. <font size="3"><img{if $attach['price'] && $_G['forum_attachmentdown'] && $_G['uid'] != $attach['uid']} class="attprice"{/if} style="cursor:pointer" id="aimg_$attach[aid]" aid="$attach[aid]" src="{STATICURL}image/common/none.gif" onclick="zoom(this, this.getAttribute('zoomfile'), 0, 0, '{$_G[setting][showexif]}')" zoomfile="{if $attach[refcheck]}forum.php?mod=attachment{$is_archive}&aid=$aidencode&noupdate=yes&nothumb=yes{else}{$attach[url]}$attach[attachment]{/if}" file="{if $attach[refcheck]}forum.php?mod=attachment{$is_archive}&aid=$aidencode{else}{$attach[url]}$attachthumb{/if}" inpost="1"{if $_GET['from'] != 'preview'} onmouseover="showMenu({'ctrlid':this.id,'pos':'12'})"{/if} /></font>
將上述代碼最后一句
  1. <font size="3">$_GET['from'] != 'preview'} onmouseover="showMenu({'ctrlid':this.id,'pos':'12'})"{/if} /></font>
修改為:
  1. <font size="3">$_GET['from'] != 'preview'} {if $firstpost && $_G['fid'] && $_G['forum']['picstyle'] && ($_G['forum']['ismoderator'] || $_G['uid'] == $attach['uid'])}onmouseover="showMenu({'ctrlid':this.id,'pos':'12'})"{/if}{/if} /></font>
以及修改第260行,源代碼如下:
  1. <font size="3"><img{if $attach['price'] && $_G['forum_attachmentdown'] && $_G['uid'] != $attach['uid']} class="attprice"{/if} id="aimg_$attach[aid]" aid="$attach[aid]" src="{STATICURL}image/common/none.gif" zoomfile="{if $attach[refcheck]}forum.php?mod=attachment{$is_archive}&aid=$aidencode&noupdate=yes&nothumb=yes{else}{$attach[url]}$attach[attachment]{/if}" file="{if $attach[refcheck]}forum.php?mod=attachment{$is_archive}&aid=$aidencode&noupdate=yes{else}{$attach[url]}$attach[attachment]{/if}" $widthcode id="aimg_$attach[aid]" inpost="1"{if $_GET['from'] != 'preview'} onmouseover="showMenu({'ctrlid':this.id,'pos':'12'})"{/if} /></font>
最后一句代碼:
  1. <font size="3">$widthcode id="aimg_$attach[aid]" inpost="1"{if $_GET['from'] != 'preview'} onmouseover="showMenu({'ctrlid':this.id,'pos':'12'})"{/if} /></font>
修改為:
  1. <font size="3">$widthcode id="aimg_$attach[aid]" inpost="1"{if $_GET['from'] != 'preview'} {if $firstpost && $_G['fid'] && $_G['forum']['picstyle'] && ($_G['forum']['ismoderator'] || $_G['uid'] == $attach['uid'])}onmouseover="showMenu({'ctrlid':this.id,'pos':'12'})"{/if}{/if} /></font>
并刪除第267行源代碼,如下:
  1. <font size="3"><a href="forum.php?mod=attachment{$is_archive}&aid=$aidencode&nothumb=yes" target="_blank">{lang download}</a></font>
如果有第三方模板,在模板里找到該文件,同樣的操作,就可以去掉“下載附件”字樣。
X3.5這個文件看了,代碼有點差異,不知道如何修改才能刪除“下載附件”提醒,求指教!
1 貢獻(xiàn)+1 金幣
21 個
 樓主| 發(fā)表于 2024-6-19 10:26:36 |廣東| 只看Ta
復(fù)制過來的代碼有點問題,沒辦法刪除和修改,說明一下
每一段前面都加了
  1. <font size="3">
可能是調(diào)整了字體,自動加了這一段
8 點
14 個
發(fā)表于 2024-6-19 13:52:26 |重慶| 只看Ta
或者干脆去應(yīng)用中心買個插件
發(fā)表于 2024-6-19 16:44:18 |江蘇| 只看Ta
21 個
 樓主| 發(fā)表于 2024-6-19 19:55:58 |廣東| 只看Ta
按照你的截圖,在后臺選擇“是”,隱藏附件信息條,但不起作用,鼠標(biāo)指到圖片上,還是會顯示附件名稱,下載附件提示信息等。也嘗試在論壇板塊編輯中,尋找是否有設(shè)置的選項,也沒找到
我用這個改3.5的沒問題,不妨試試---https://boonkiong.com/thread-3046-1-4.html
發(fā)表于 2024-6-19 20:51
發(fā)表于 2024-6-20 10:07:09 |江蘇| 只看Ta
技術(shù)控 發(fā)表于 2024-6-19 19:55
按照你的截圖,在后臺選擇“是”,隱藏附件信息條,但不起作用,鼠標(biāo)指到圖片上,還是會顯示附件名稱,下 ...
要么你模板就不是X3.5默認(rèn)模板
發(fā)表于 2024-6-20 10:29:53 |浙江| 只看Ta
X3.5后臺自帶設(shè)置即可,如果無效,說明你的模板沒做這塊的3.5兼容
21 個
 樓主| 發(fā)表于 2024-6-20 19:45:53 |廣東| 只看Ta
科站網(wǎng) 發(fā)表于 2024-6-20 10:07
是的,用了第三方模板。是不是只需要去修改第三方模板forum/discuzcode.htm文件里的代碼,默認(rèn)的模板代碼不需要修改?
21 個
 樓主| 發(fā)表于 2024-6-20 19:46:59 |廣東| 只看Ta
湖中沉 發(fā)表于 2024-6-20 10:29
用了第三方模板。是不是按照X3.4的方法,修改forum/discuzcode.htm里的代碼?
發(fā)表于 2024-6-20 20:41:05 |浙江| 只看Ta
技術(shù)控 發(fā)表于 2024-6-20 19:46
是,但第三方模板,有可能這些部分也做了自己的個性化修改的
GMT+8, 2026-4-18 11:14 , Processed in 0.056924 second(s), 16 queries , Redis On.
