查看: 1872|回復(fù): 2
[求助] Discuz! Database Error問題怎么處理
發(fā)表于 2024-10-6 12:19:37 |浙江| 只看樓主 |倒序?yàn)g覽 |閱讀模式
(1114) The table 'common_visit' is fullINSERT INTO common_visit SET `ip`='1944037449' , `view`='1'
PHP Debug
No.FileLineCode
1forum.php67require(%s)
2source/module/forum/forum_viewthread.php33helper_antitheft::check(%s, %s)
3source/class/helper/helper_antitheft.php17helper_antitheft::check_allow(%s, %s)
4source/class/helper/helper_antitheft.php60discuz_table->insert(Array)
5source/class/discuz/discuz_table.php81discuz_database::insert(%s, Array, false, false, false)
6source/class/discuz/discuz_database.php60discuz_database::query(%s, %s, %s, true)
7source/class/discuz/discuz_database.php139db_driver_mysql->query(%s, %s, true)
8source/class/db/db_driver_mysql.php152db_driver_mysql->halt(%s, %d, %s)
9source/class/db/db_driver_mysql.php223break()
發(fā)表于 2024-10-6 15:51:23 |河南| 只看Ta
可能是你 磁盤空間滿了
發(fā)表于 2024-10-6 16:47:15 |浙江| 只看Ta
表滿了?僅數(shù)據(jù)庫管理里面去看看吧
GMT+8, 2026-4-19 07:48 , Processed in 0.044303 second(s), 12 queries , Redis On.
