查看: 1186|回復(fù): 3
[已解決] 循環(huán)調(diào)用最新帖子,能加上帖子的簡(jiǎn)介嗎?
14
發(fā)表于 2024-11-16 10:59:58 |山東| 只看樓主 |倒序?yàn)g覽 |閱讀模式
<!--{eval $slides = DB::fetch_all("SELECT * FROM %t WHERE fid=%d ORDER BY `dateline` DESC LIMIT 0, 6",array('forum_thread',$_G['fid']));}-->
<ul class="cl">
<!--{loop $slides $slide}-->
<li><span>&#8226;</span><a href="forum.php?mod=viewthread&tid=$slide[tid]" title="$slide[subject]" target="_blank" >$slide[subject]</a></li>
</li>
<!--{/loop}-->
        </ul>
試試
  1. <!--{eval $slides = DB::fetch_all("SELECT t.tid, t.subject, p.message FROM %t t LEFT JOIN %t p ON t.tid = p.tid WHERE t.fid=%d AND p.first=1 ORDER BY t.dateline DESC LIMIT 0, 6", array('forum_thread', 'forum_post', $_G['fid']));}-->
  2. <ul class="cl">
  3. <!--{loop $slides $slide}-->
  4. <li>
  5.     <span>&#8226;</span>
  6.     <a href="forum.php?mod=viewthread&tid=$slide[tid]" title="$slide[subject]" target="_blank">$slide[subject]</a>
  7.     <p>{echo cutstr(strip_tags($slide['message']), 100)}</p>
  8. </li>
  9. <!--{/loop}-->
  10. </ul>
7 點(diǎn)
9 個(gè)
發(fā)表于 2024-11-16 13:13:44 |安徽| 只看Ta
試試
  1. <!--{eval $slides = DB::fetch_all("SELECT tid, subject, message FROM %t WHERE fid=%d ORDER BY `dateline` DESC LIMIT 0, 6", array('forum_thread', $_G['fid']));}-->
  2. <ul class="cl">
  4. <li>
  7.     <p>$slide[message]</p> <!-- 添加帖子簡(jiǎn)介 -->
  8. </li>
  9. <!--{/loop}-->
  10. </ul>
 樓主| 發(fā)表于 2024-11-16 14:42:36 |山東| 只看Ta
(1054) Unknown column 'message' in 'field list'
7 點(diǎn)
9 個(gè)
發(fā)表于 2024-11-16 14:49:04 |安徽| 只看Ta
試試
  2. <ul class="cl">
  4. <li>
  8. </li>
  9. <!--{/loop}-->
  10. </ul>
GMT+8, 2026-4-18 04:14 , Processed in 0.041214 second(s), 13 queries , Redis On.
